Gas Gauge
Old Nov 2, 2008 | 11:22 PM
mosgo1's Avatar
mosgo1
Gas Gauge
Some idiots tried to steal my truck and cut all the wires out of my 79 supercab.
I can't get the gas gauge to work! If I run new wires from my tank,One is ground and the other goes to the gauge..But what side? And do I have to put power to the Gauge? Pleeeze Help!! I need to know how to re wire my gauge.
thanks]
moses
Old Nov 3, 2008 | 05:25 AM
TexasRho83's Avatar
TexasRho83
thanks]
moses
Are you using aftermarket guages?
Old Nov 3, 2008 | 11:29 AM
mosgo1's Avatar
mosgo1
No, its the stock gauges.
Old Nov 3, 2008 | 01:42 PM
fmc400's Avatar
fmc400
MSEE
The sending unit is basically a variable resistor\potentiometer\rheostat. Many names for the same thing. There are two wires coming from it - a black wire which grounds to the frame, and a yellow wire which goes up to the instrument cluster. It runs the length of the frame and goes in through the firewall, along with the tail lights, rear turn signals and reverse lights.
Old Nov 3, 2008 | 03:54 PM
mosgo1's Avatar
mosgo1
Since there is two posts on the gauge, do I need a ground to the gauge on one of the posts on the back along with the sending unit wire on the opposite post?
Old Nov 3, 2008 | 06:56 PM
fmc400's Avatar
fmc400
MSEE
I thought one post of the gauge was for power and the other post was the sending unit wire. If no one else here can verify this, I'd try posting in the electrical forum because some guys over there have access to a lot of wiring diagrams. I can't remember if the gauge sources power from regular battery voltage, or the regulated instrument cluster voltage which is much lower.
