Attention MECHANICS!!!! Any Advice??
I have a 91' E350 w/ a str.6 motor. Just purchased so this is all new to me. The problems:
Day1-Noticed antifreeze leak coming from water pump.
*Water pump was replaced.
Day2-Drove van to work all was fine, drove van home started getting hot. It never made it all the way to the "H" side but close. Once shut off, steam was coming from overflow tube. 5min. later "poof" rubber hose from bottom of radiator split, water everywhere, also noticed a leak inside van from heater core I assume. Nut much but enough to notice.
* I replaced both upper and lower hoses as well as installing a new "fail safe" thermostat.
Day3- After finishing hose and thermostat install I changed oil and filter, I filled with new antifreeze and I did have the engine running to top off the water. Went for test drive 10min later started getting hot again. Pulled over had a little steam. Waited about 45min and started back home, temp gauge barely came off of "C" on gauge.
I am assuming that it got hot again and that "fail safe" thermostat I purchased did its job and is now stuck open which is why it is not moving anywhere on temp gauge.
I talked to a few people and the suggestions that I have are to install a new thermostat and replace the heater core. Im at a loss here, I thought replacing the thermostat would have solved the overheating. Ive ruled out a head gasket being blown, with the engine running and radiator cap off there are not any bubbles from the water, and of course checking the oil for signs of water, all seems ok there..
Any tips or suggestions?
Thanx
Thanx
