Water Dripping
Old Nov 1, 2008 | 02:38 PM
deepsouthdrilling's Avatar
deepsouthdrilling
Water Dripping
My 04 6.0 is dripping coolant (running or not) from the back of the engine on the passenger side I can't tell exactly where it is coming from, it looks to be running around the back of the head and dripping down on the starter. The truck runs pulls and performs great and starts well. It has 60k on it. any ideas?
thanks
Old Nov 1, 2008 | 05:46 PM
dcaddi2's Avatar
dcaddi2
thanks
There are a few possible locations you can lose coolant at that area.
- oil cooler - if the gasket is damaged
- EGR cooler - gasket/ o ring damage or EGR itself leaking
- EGR cooler coolant deaeration port - that's the small hose going towards the degas bottle from the intake area.
To pinpoint where you losing coolant will be a PITA, be patient.
Old Nov 1, 2008 | 07:44 PM
toolman05kr's Avatar
toolman05kr
Check the heater controll valve, it's right above the passenger side valve cover near the back of the engine. I have changed dozens of these because of leaking.
Old Nov 2, 2008 | 04:35 PM
deepsouthdrilling
Thanks Guys as luck would have it has stopped now and I just went out of warranty on the 16th of Oct.
Old Nov 3, 2008 | 11:02 AM
skoveng's Avatar
skoveng
I have the same problem with my '03. It has happened twice in as many years. It seam to happen after an all-day run just when the weather changes towards cold. I have identified the problem as being the short hose that runs between the oil cooler and the egr cooler. It's on my list to change one of these days. It may be a warranty issue as I have read elsewhere in FTE; my truck is out. Good luck.
Old Nov 3, 2008 | 12:11 PM
NC250's Avatar
NC250
Was it a cooler day than usual when you seen the leak? and was it a warmer day when it went away? If so, it's more than likely the EGR cooler hose. Mine acted the same way. When its cold and the hose shrinks, it leaks. When its warm and the hose expands, the leak seals. Its about a $30.00 part but a pain to get at.
Here is a good picture of where to look.
Page 74: Unique Service Procedures
Old Nov 3, 2008 | 05:20 PM
deepsouthdrilling
Thanks again guys I believe the oil cooler to egr hose is the culprit it has stopped for now I am headed back offshore tomorrow so I will have to wait untill I get back in to deal with it.
