water in fuel help
Old Nov 1, 2008 | 02:20 PM
212nut's Avatar
212nut
water in fuel help
someone blessed my 1992 f-150n 4.9 with water in my fuel tank. got out what i could, all but maybe a gallon. put three bottles of dry gas and ten gallons of new gas. new plugs and she still doesnt want to fire. is there another product i can use to get the rest out? any help please.
Old Nov 1, 2008 | 02:25 PM
mstngmikegt's Avatar
mstngmikegt
suppose you could try a heavy dose if IsoHeet...or is that what you meant by "dry gas"? You sure it was all water added, not a sugar 'solution'? May want to change the fuel filter too just to be safe (maybe 2 times...once before and once after awhile of running)
Old Nov 1, 2008 | 02:40 PM
quicklook2's Avatar
quicklook2
does it start with starting spray?
water in tank usually just makes it run bad but it will still run.
Old Nov 1, 2008 | 02:52 PM
212nut's Avatar
212nut
yeah it runs on starting spray. the plugs are wet, but water is always at the bottom of a gas tank. i changed the filter and i also have 60psi to the rail. sometimes it fires. spark is great, maybe it was sugar water
Old Nov 1, 2008 | 03:12 PM
quicklook2's Avatar
quicklook2
remove fuel filter, drain tank, replace filter, replace fuel.
no easy answer.
Old Nov 1, 2008 | 04:01 PM
212nut's Avatar
212nut
done this. it seems like the water js still between the filter and the plugs. i have cranked it to try to get it to fire with no luck. the plugs get wet with water????????? hit them with plug cleaner and put in, but still seems to have water
Old Nov 1, 2008 | 04:03 PM
quicklook2's Avatar
quicklook2
put new copper plugs in.
start it with starting spray 5-10 times that should use up any fuel in line.
again, no easy answer.
Old Nov 1, 2008 | 04:23 PM
212nut's Avatar
212nut
i am going to throw another set of plugs in
Old Nov 4, 2008 | 05:59 PM
212nut's Avatar
212nut
nks to all finally got her fired
Old Nov 4, 2008 | 06:19 PM
quicklook2's Avatar
quicklook2
so what finally did it?
the fresh plugs?
Old Nov 4, 2008 | 06:30 PM
mstngmikegt
glad to hear it's alive again. curious too, what was the fix? plugs,combo or just good karma?
Thunderhorn
1978 - 1996 Big Bronco
May 1, 2014 08:18 PM
Rishsd
31
Jun 6, 2013 06:53 PM
jwalker1970
Jun 7, 2012 01:12 PM
raygant
Jan 7, 2012 01:36 PM
MadMichaelJ
Feb 22, 2008 11:19 PM
