Sponsored by: Kumho
90 F-150 IFS44 to solid front
Old Nov 15, 2002 | 05:46 PM
fordconversion's Avatar
fordconversion
Post 90 F-150 IFS44 to solid front
I have a 1990 F-150 with a 6" coil spring lift and 3" body. I have found a 1974 F-250 with dana 44HD front axle. What has to be done to the axle to receive the coils and how does the steering need to be changed?
Old Nov 15, 2002 | 05:49 PM
mooktank's Avatar
mooktank
I dont really know but im guessing if the axle was set up for leafs you could weld the little coil perch thing on. Maybe make it taller and get some more lift out of it. just an idea.
Old Nov 16, 2002 | 02:17 AM
Ryan50hrl's Avatar
Ryan50hrl
i'm working on the same conversion right now...I'm making a square block that mounts over the axle. as for the steering, i haven't got to that yet.
RYan
Old Nov 16, 2002 | 01:58 PM
RedXL's Avatar
RedXL
I'm working on a similar conversion for my 93 F150 4x4. I also bought a Dana44HD. I was going to weld spring perchs where the leaf springs mounted, but I'm not sure how to mount the radius arms. I've been thinking about a 4-link setup with rodends and a panard rod. I believe you can change to "DANA 44 Hi-Steer/Cross Over Arms". They are forsale on ebay all the time. Just do a search, on ebay, on the above phrase in quotes. You can see these arms installed at www.shakerbuilt.com.
Ray
Old Nov 16, 2002 | 05:55 PM
RBrendel's Avatar
RBrendel
Old Nov 17, 2002 | 01:31 PM
steve83's Avatar
steve83
Here's another option:
http://hometown.aol.com/jzettel73/TTB_Conversion.html
Reddogg0_1
Aug 4, 2014 08:41 PM
JP808
Sep 12, 2012 09:32 PM
351slug
Offroad & 4x4
Dec 17, 2009 08:12 PM
ShortboxF150
Mar 16, 2007 11:23 AM
