fule filter replacement
Old Oct 31, 2008 | 09:43 PM
luvemhot's Avatar
luvemhot
My question is how do I remove the clips that hold the hose on the filter? Do I just break them out? when I tried to remove one with a screw driver it broke the end. Do I need a special tool? more patience?
thanks for the help
2003 exp with the 5.4
Old Nov 1, 2008 | 05:50 AM
Gevans17's Avatar
Gevans17
clips on fuel line
dont break them..just pry / pull the "open" end of the clip down and off of the fuel line. Then Let the clip hang out of the way...You will then need a special tool to push into the filter on each end to release the line from the filter. It is a pain to change, but its another of Fords "better" ideas. Good luck
Old Nov 1, 2008 | 07:21 AM
Modified 99's Avatar
Modified 99
Exclamation
I agree, the filter is a PIA to change, but necessary. I change my fuel filter once a year. This time I cut it apart to observe the filter media color. The color was a dark brown and one of the filter pleats was bent in, meaning that the differential pressure across the filter was HIGH. The vehicle had about 20K since last fuel filter change. This is just a guess but I think the ethanol corrodes steel much faster which could come from various sources after the ethanol is blended in. My 99 has about 164K on it now and I have never had an injector issue. Maybe I'm just lucky on this point.
Old Nov 1, 2008 | 10:08 AM
Icefan71's Avatar
Icefan71
Yep, you need the stupid plastic special tool. It makes the job so much easier. Although, I must admit I did have some difficulty. Changed mine w/ appx 90k miles on vehicle.
Old Nov 1, 2008 | 07:51 PM
luvemhot's Avatar
luvemhot
Thanks for the help I will get the tool I have a gas line tool for my 350 but I dont see how it will work for this type unless after I get the clips out of the way then I use to push in towards the filter. thanks again.
Old Jan 20, 2009 | 12:25 PM
jabsdb's Avatar
jabsdb
What is this "special tool" and where can I get it from?
Old Jan 20, 2009 | 02:18 PM
Frat-man-du's Avatar
Frat-man-du
Any chain auto parts store has them - they often come in a kit with different sizes.
PITA to do but once you do it a few times you get used to the tool and the process to pop off the line.
Old Jan 20, 2009 | 04:20 PM
dr cabela's Avatar
dr cabela
do what i do
next time u change your oil get them to change the filter u bought for 10-20 bucks
easy that way
Old Jan 20, 2009 | 07:02 PM
madsonp's Avatar
madsonp
Here's a little write up on how to change the filter. They use a metal tool, but like mentioned above you can get the cheaper plastic ones. How to Replace The Fuel Filter In Your Ford F-150
Old Jan 21, 2009 | 12:59 PM
kitty*on*22's's Avatar
kitty*on*22's
Word to the wise: if you're hard on your tools or impatient (like me) go ahead and buy the metal tool, the plastic one will break!
Old Jan 21, 2009 | 09:13 PM
Z06PSI's Avatar
Z06PSI
I agree. The metal one is good and one end works with GM and the other works with Ford. Pretty slick device.
