Spark Plug Preferences
Old Nov 4, 2008 | 05:34 PM
Alan D.'s Avatar
Alan D.
I actualy may have a set ro two of those from my grand pappies barn. Lol. I'm fairly certain they have a bitt more rust than that though.
Old Nov 4, 2008 | 05:45 PM
Lead Head's Avatar
Lead Head
If they are the legit Polonium plugs, they may be worth something
Old Nov 5, 2008 | 06:29 PM
Peter94's Avatar
Peter94
Originally Posted by 4scottdcham
spark plugs would not cause condition and vac leak would not just cause an efect at rpm check fuel psi and amount of delevery during condition if ok peplace ecu
Are you kidding me?
Have you ever worked on a car?
Yeah, lets just throw an ECU at it! Thats only like what, a $500 bo-bo or so!
Spark plugs will cause a misfire under load, because as load increases, so does the resistance of the spark to jump the gap in the cylinder. If the resistance of the spark plug gap is higher than the resistance of say the gap where the wire is resting next to any piece of grounded metal, it will jump through the wire to ground, completely bypassing the spark plug, therefore causing a misfire.
Same with a vacuum leak. Engine is taking in X amount of air through the throttle body, and X amount of air through vacuum leak. The MAF only knows about the amout going through the throttle body. Lean condition (especially if it is in an intake runner) could cause a misfire.
How about a bad MAF? ECT? even a bad TPS can cause a misfire under acceleration!
I dont mean to be rude, but If I had no idea what I was doing, and followed your advice, and put a PCM in my vehicle, and it didnt fix it, I would be pretty mad.
P.S., I read a statistic (somewhere) that like 75% of all PCM's returned as defective, are actually just fine, and were returned because the problem was mis-diagnosed.
Old Nov 5, 2008 | 07:15 PM
Alan D.'s Avatar
Alan D.
Thanks pete. I didn't think there was anything wrong with my pcm/ecu. they have never gotten wet, or been shorted out. I never heard of them failng unless mis used or abused.
Old Nov 5, 2008 | 08:55 PM
4scottdcham's Avatar
4scottdcham
Originally Posted by Peter94
Are you kidding me?
I don't mean to be rude, but If I had no idea what I was doing, and followed your advice, and put a PCM in my vehicle, and it didn't fix it, I would be pretty mad.
Wow I see your for sight is right on the money and don't hold back let every member see the difference between "hands on" experience and book smart witch I will not belittle or assume years of experience. thanks for the exercise in stupidly sorry you replaced to Manny pcm's
Old Nov 5, 2008 | 10:07 PM
Alan D.'s Avatar
Alan D.
OI, No highjacking my thread for pointless aurguments!!
I'm fairly certain that it says somewhere in the rules that only the original poster may start an aurgument on his/ her post. And if it doesn't, it should.
Peter94 is right, though perhaps a little harsh. The pcm isn't nearly as likely as the issues he suggested, especially regarding the vacuum leak, which was the case as one of the lines had dry-rotted and cracked.
Forest
Jan 13, 2015 10:17 AM
rbloodhound
Louisiana Chapter
115
Feb 28, 2011 06:37 AM
Traxxis
Feb 17, 2010 09:26 PM
petes79f150
Oklahoma Chapter
Jan 10, 2006 01:40 PM
Steelbass
Jun 21, 2004 10:36 PM
