1989 bouncy speedometer
Old Oct 31, 2008 | 08:46 AM
89ford73's Avatar
89ford73
is there a simple cure for the bouncy speedo on my 89 f150? at 45 it bounces like crazy. when i get up to 70 it levels out.
Old Oct 31, 2008 | 09:47 AM
jnewkirk77's Avatar
jnewkirk77
I'm not 100% sure, but on every other cable-driven speedo I've had to deal with, lubricating the cable (as I recall, I used a graphite-based lube) took care of the problem.
Is there any chance the cable could have gotten kinked somewhere? I reckon that could also cause it.
Old Oct 31, 2008 | 10:21 AM
alxsnmr's Avatar
alxsnmr
Also check that the cable is secured by the tap at the trans.
Old Oct 31, 2008 | 10:34 AM
bomberboat's Avatar
bomberboat
white grease works also
Old Oct 31, 2008 | 01:19 PM
jnewkirk77's Avatar
jnewkirk77
White grease does work, but any time I've ever used it, it gets pretty gummy. I don't know if that would help or hurt in the long run ...
Old Oct 31, 2008 | 11:28 PM
HrdDrv's Avatar
HrdDrv
I always shot WD-40 down the cablesleeve top-to-bottom.
Old Nov 1, 2008 | 06:14 PM
89ford73's Avatar
89ford73
ok, i ill check out my cable. i have had it out a few times when in the process of putting in the clutch pedal and swapping in the transmission and engine from a dodge-cummins. its not too hard to pull out and slick up. thanks for the input.
