Freshly Rebuilt E4OD
Old Oct 30, 2008 | 12:05 PM
Hollow647's Avatar
Hollow647
Angry Freshly Rebuilt E4OD
Here's the deal I bought a 1996 1 ton Bucket truck with a 460. The tranny was slipping and stalling when i put it into gear. I had the trans rebuilt...new planetaries, trans cooler, torque converter. The slipping was cleared but the engine still want's to stall when i put it into gear. I have done a tune up, the motor doesn't seem to have a miss. The truck has duel tanks and i am getting the same symptoms off of both tanks. Please help if you can.
Old Oct 30, 2008 | 12:26 PM
DJdemon6696's Avatar
DJdemon6696
chek your IAC.. maybe its dirty.. a dirty or bad IAC causes low idle and stalling in gear..
Old Oct 30, 2008 | 12:30 PM
Hollow647's Avatar
Hollow647
excuse my ignorance but what is the IAC
Old Oct 30, 2008 | 12:57 PM
qman's Avatar
qman
Idle Air Control Valve. It sits on the throttle body and allows air to enter when idling. When you step on the gas pedal you open the throttle butterfly. When idling the butterfly is completely closed and the only way for the engine to continue running is to get some air through the IAC valve. It's pretty much just a bypass for air.
You can remove it and blast it with carb cleaner to clean it up. Then there's the electronic control module. I guess it can be bad too but I've got nothing for you in that arena.
Old Oct 30, 2008 | 01:18 PM
DJdemon6696
jep... just begin by cleaning it.. and see if it improves
Old Oct 30, 2008 | 02:33 PM
Hollow647's Avatar
Hollow647
thanks i'll try it out
