SD Winter Storage
Should I remove the battery or leave in and fire it up every so often (every month, two months or?).
I'm going to block it up to take the weight off the springs so it won't be movable but when it comes time to put it back on the road are there any precautions I should take?
I will fill the gas tank and add a gas preservative.
Any other suggestions would be appreciated.
Plus gas is getting cheap, this winter will be a whole new driving experience
Anyhow, if you are gonna store it make sure to add fuel stabilizer, unhook battery, don't start it up while it's sitting unless you plan to run it for at least an hour because of the condensation that builds up in the crank case. I would also make sure there is adequate di-electric grease in all your COP's and put a solid coat of carnauba wax on your paint.
Also, if you are putting a cover on it make sure it is securely fastened, I've seen cheap ones abraid paint pretty good from wind flapping. If no cover, I would say put a sun shield in the window to offset sun fading. If it has a soft tonneau put the UV protection treatment on that too.
If you are going to change the oil, I've always heard do it when the beast comes out of hibernation, not before.
Good luck!
Search some older threads, there was a good discussion on using marine fogging oil in gas engines that are going to sit in wet environments for a long time.
When you drop it off the blocks six months from now, check your tires pretty carefully before you pump them back up to the max, even the stems and vavle cores.
I don't know if this is important on newer motors or not?
-Dave
I'd disconnect the battery.
If you want to crank the engine over a little to get oil up to the cams before it starts, pull the fuel pump fuse.
As for fogging the motor, that's a LOT of work - you basically spray fogging oil into the intake as it runs until it chokes and dies. Then, you are stuck changing or cleaning the plugs, AND - it'll probably ruin the catalytic converter!
6 months isn't too long. But, if you're going to be around, I'd be more likely to start the engine and let it run for 1/2 hour or so to get it really nice and warm, and make sure the cylinders (and cams and valves/guides) don't get too dry and rust.
Good luck!
Trans AM? not......how about an '89 5.0 LX factory ordered the way I wanted it. The SD goes to bed this winter because it's "working days" are over (like me). Just needed for goiong to my favorite trout lake in the spring and fall.
I have been partial to F-bodies over Fox Body mustangs for a while, granted I've had my fair share of fun in the 'stangs. '91 Camaro RS, '92 Camaro RS, '85 Iroc, and now that all them cars are gone
I got me a '78 Trans Am very similar to a bandit but metallic burgandy and no t-tops. Still, no car is a comfy as a SD and I'm just used to it coming out of it's hibernation for winter time
