Bronco II Ford Bronco II
87 Bronco II Fuel pump, electrical problem!
Old Oct 30, 2008 | 01:22 AM
Sam in Va's Avatar
Sam in Va
Exclamation 87 Bronco II Fuel pump, electrical problem!
Help! My bronco is sitting in a praking lot and has been for two days now. Got back in it to leave and it will crank but it won't turn over. Narrowed the problem down to what we belive is an electrical problem with the fuel pump. We manually ran juice to the in-line high pressure pump from the battery and it turned on fine and caused pressure to build in the fuel rail ( wich was not there before hand). We are having a little trouble locating the relay for it as well. We also cannot trace the wire from the high pressure FP to it's relay. Yes I also have the HAYNES book and it is of very little help. I really need to get it out of this lot before it is towed. Any one have any suggestions other than blowin' it up?
Old Oct 30, 2008 | 09:04 AM
rebocardo's Avatar
rebocardo
There is another topic a few spaces away dealing with the same type of issue. First, check the cut off switch (pass. side cab near transmission hump) and check the relay, which is on the pass. fender under the hood
Old Nov 3, 2008 | 10:53 AM
bronco five o's Avatar
bronco five o
i recently had the same problem, it was a little wire connected to the positive terminal of the battery and i has a clip that is real flimsy and broke off give that a shot
Old Nov 4, 2008 | 05:48 PM
rebocardo's Avatar
rebocardo
Never seen that on any B2, I think you have an after market alarm or kill switch installed.
Old Nov 5, 2008 | 12:31 AM
97Centurion's Avatar
97Centurion
Rub my Belly
On mine there is a ground wire from the battery negative terminal that goes into the wire loom. It has a connector that looks similar to an round fuse holder. I think it goes to the relays. Not sure though. I know if it's unplugged or has a bad connection, The fuel pump won't work. Maybe that's what "five o" is thinking.
skalrim1134
1978 - 1996 Big Bronco
Dec 24, 2010 02:30 AM
fast2174
Sep 17, 2010 12:12 PM
cje07
Mar 23, 2010 01:37 PM
lopitt85
Sep 1, 2009 08:54 PM
smose
Electrical Systems/Wiring
Mar 27, 2004 04:43 PM
