gas gauge
Old Oct 29, 2008 | 07:26 PM
ggwash21's Avatar
ggwash21
gas gauge
So i went to fill up this evening and i was below half tank and after i filled up it didnt move... now it shows between 3/4 and full and went up really really slow.... any ideas????
Old Oct 29, 2008 | 07:39 PM
shorebird's Avatar
shorebird
Was the truck turned off while you filled up? If you fill up with the key in the on position the gauge will seem to be slow. Turn off the engine and fill up and when you restart the engine the gauge should operate normally.
Old Oct 29, 2008 | 08:06 PM
ggwash21's Avatar
ggwash21
nope truck was off, i pounded on the bottom of tank and even waited and went back out and started truck up now and still not on the full mark..... talk about a crappy night... first this then in the holiday car wash and the dam car wash peeled my pass mirror backwards ..... then pizza hut screwed up my order... LOL i came home locked doors and shut phones off i'm gonna lock my self in closet if i need too lol
Old Oct 30, 2008 | 06:05 AM
dixiemudder04's Avatar
dixiemudder04
Just dont type a thread saying u came out of that closet. But seriously its sounds like the float. I have a 78 that used to do that. I took it out and moved the float up and the gauge went to full. But when i put it back it would only read like 1/8. I believe i finally swapped it out from a truck i had and that fixed it.
Old Oct 30, 2008 | 09:07 AM
2004 xlt 5.4's Avatar
2004 xlt 5.4
even if engine is off if some how you turn key on but not motor while filling gas it well not read properly even with restarting it will gradually go to full may not show till next time you drive it something weird in the computer
Old Oct 30, 2008 | 11:14 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
also, a low battery will cause this condition. it makes all the gauges read funny, and the fuel gauge is often the first one to do so
Old Oct 30, 2008 | 11:19 AM
ggwash21's Avatar
ggwash21
thanks i will have the battery and charging system tested this afternoon...
thanks a ton guys
Old Oct 30, 2008 | 11:41 AM
firedog550's Avatar
firedog550
Mine did this once before also... Drove it like that for a couple of days and filled up again. It was fine after that. It went up fast, and did everytime I turned the ignition on. Don't know what caused it, just that it worked. Let me know.
Old Oct 30, 2008 | 12:06 PM
ggwash21's Avatar
ggwash21
well this morning on the way too work it finally went up to the full mark and after driving awhile it is going down with the gas in the tank so i will know when i fill up next.. Still gonna have the battery tested etc..
Old Oct 30, 2008 | 12:59 PM
zag's Avatar
zag
Try pouring a bottle Chevron Techron additive into the tank. It frees up many contacts on the sending unit.
Good Luck
Old Oct 30, 2008 | 01:18 PM
jstnromero's Avatar
jstnromero
ya i was gonna ask what type of gas you are running....some of the nicer gas stations Chevron, Shell etc all have additives that help clean/keep clean the gas system....you may just have a gummed up float or something....just a thought
Old Oct 30, 2008 | 01:33 PM
ltrager's Avatar
ltrager
I had this happen to me this past week. I had left the keys in the ignition while I filled up. The truck was off. Anyway, the next time I removed the keys and the gauge was back to normal.
Old Mar 7, 2009 | 08:31 PM
Ryan50hrl's Avatar
Ryan50hrl
Ok....happened to me today....filled it up from EMPTY.....and it took 40 miles to read full....anyone figure out the cause???
Old Mar 7, 2009 | 08:47 PM
Still Smoking's Avatar
Still Smoking
mine does it sometimes too dont know why though
Old Mar 7, 2009 | 09:14 PM
bridge's Avatar
bridge
Sick 'n Tired
It's happened to both my F150 and Expy...just does that sometimes.
