Sponsored by: Kumho
Hard Steering '34 Ford P/U
Old Sep 14, 2001 | 12:26 PM
CougarJohn's Avatar
CougarJohn
I have a '34 Ford with a side steering setup (box from an early '60's P/U), original axle and front suspension, and steel wheels. The thing turns and steers like a, well, truck. Very hard to turn.
A buddy looked at it and pointed out that the center point of tire contact with the road is about 2 1/2" out from the point where the line down to where the kingpin hits the road. This is "scrub radius."
I am told that getting an offset wheel to pull the contact point in closer to the center of the vehicle will alleviate, possibly cure the problem.
Before I go dumping big bucks, can you guys advise? I have plenty of clearance to offset in. What offset should I go for? What scrub radius is proper? I am running wide 10" tires front and rear by the way. That may be another part of the problem.
Old Nov 28, 2002 | 10:46 AM
rickbergquist's Avatar
rickbergquist
Have same problem with 34 2 Dr. Seems like it is binding or needs lube. Any ideas?
Old Nov 28, 2002 | 12:12 PM
bo_95f250_4by4hd's Avatar
bo_95f250_4by4hd
BlackFartF350
Aug 29, 2012 05:22 PM
FN74
19
Mar 5, 2010 09:12 AM
biglee
1947 and Older Ford Trucks
Feb 5, 2008 09:16 AM
