Need Help!!!! Bad
Old Oct 29, 2008 | 04:00 PM
trinity's Avatar
trinity
Unhappy Need Help!!!! Bad
I changed the oil cooler gaskets on my 7.3 idi and now the oil and temp gauges don't work. they worked fine before I did the job. There is no movement now.
Old Oct 29, 2008 | 05:13 PM
alxsnmr's Avatar
alxsnmr
did you check to see if your wiring was hooked up? If so did you check to make sure the connection wasnt loose causing the loss of signal.
Old Oct 29, 2008 | 09:04 PM
trinity's Avatar
trinity
Hmmmmmmmm?
I don't remember disconnecting any plugs when I did it.
Old Oct 30, 2008 | 08:06 AM
Lazy K's Avatar
Lazy K
Post this on the pre-powerstroke diesel page, there are plenty of guys there who will be able to help.
