Water pump problems
Old Oct 29, 2008 | 08:51 AM
bulldogcountry1's Avatar
bulldogcountry1
Water pump problems
I have a 351W with only 3000k miles, and twice now, I've have a bad leak out of the bottom of the pump. Both times, I have removed the pump to find the steel backing plate warped into the pump shaft. This warping is causing the gasket seal to fail. I have no idea what is doing this. Any ideas?
