Sponsored by: Real Truck
Rim size
Old Oct 28, 2008 | 10:18 AM
mkanning's Avatar
mkanning
Rim size
Hi, my question is I have an 07 f250 4x lariat it came with 18 inch rims,will a 17 inch rim work (clear the calipers) on this truck? Thanks Mitch
Old Oct 28, 2008 | 10:34 AM
senix's Avatar
senix
If you have one or know someone that does I would suggest just trying it to be sure.
Old Oct 28, 2008 | 11:45 AM
brian42's Avatar
brian42
Veteran: Navy
Measure the distance from the inside of the rim to the closest point on the caliper. If it's more than 1/2" your 17s should fit. I would make sure that there is going to be a little bit of a gap between the caliper and rim for any imperfections, balancing weights (depending on the kind you use) and cooling.
Old Oct 28, 2008 | 12:46 PM
DCSpecial's Avatar
DCSpecial
Stock 17s, yes.
Aftermarket 17s.....some will and others won't do to the shape of the backside of the wheel.
Old Oct 28, 2008 | 04:28 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Sorry to partialy hi-jack but ... will the Moto 951 17s fit on a 2007 SDs?
http://trucktoyzstore.com/realm/pc/v...idproduct=1453
Old Oct 28, 2008 | 06:56 PM
DCSpecial's Avatar
DCSpecial
Yes, a buddy of mine runs the 17" 951s on his 06.
17" KMC XD Series hit (at least the Diesels did on his truck), I think Eagle Alloy 17" hit as well.
Personally I recommend 18s for better tire selection, but that normally only applies to oversized tires.
