6.9 engine swap, different engines
Old Oct 28, 2008 | 12:53 AM
junkyardkid2002's Avatar
junkyardkid2002
my mechanic swapped in an 87 6.9 to my 85. the engine came from a box truck with a van front, my truck is a ramp truck f-359. the problem is the motor mounts. the engine now sits 2 inches higher, can i use f-series mounts? the engines are different.
thanks in advance
Old Oct 28, 2008 | 03:18 AM
Dodge/Cummins's Avatar
Dodge/Cummins
I COULD BE WRONG!
But I don't think the engines are different, you should be able to bolt all of the F-ser. mounts to the motor.
Someone on here will know for sure.
Old Oct 28, 2008 | 07:59 AM
fellro86's Avatar
fellro86
If I recall, it is an issue with the said mounts, and the oil cooler, otherwise, the engines are the same.
Old Oct 28, 2008 | 10:49 AM
GenLightening's Avatar
GenLightening
The van and truck had different exhaust headers and oil coolers. Swap those and you should be able to run the truck mounts.
Old Oct 28, 2008 | 05:51 PM
Dave Sponaugle's Avatar
Dave Sponaugle
junkyardkid2002,
Welcome to FTE and the IDI diesel forum.
The F series oil cooler and exhaust manifolds will bolt right on the engine as well as the motor mounts.
