transmission ???
Old Oct 27, 2008 | 09:44 AM
79tunerkiller's Avatar
79tunerkiller
transmission ???
how do i find out what 4 spd manual is in my truck behind my 390? also i have heard that a t-5 5 spd out of a 80's mustang will mate up. is this true?
Old Oct 27, 2008 | 11:25 AM
Alvin in AZ's Avatar
Alvin in AZ
Don't know nuthin about Mustangs. :/
The only two 4-speeds I've known to be behind FE's are T18's or a New Process 435.
...has it been swapped to a T19? ...synchronized in first and reverse?
I'm betting on a T18. :)
https://www.ford-trucks.com/article/...ld_Part_1.html
Alvin in AZ 360FE/T18
Old Oct 27, 2008 | 12:30 PM
masterbeavis's Avatar
masterbeavis
Avoid the mustang T5s. They could barely handle the power from the 5.0. They also will not bolt up to a 390 without some tomfoolery. The easy way to tell which 4 speed you have, NP435 has an aluminum cover, t18-19 has a cast cover. The t18-19 also has a screw on shifter retainer, the 435 has one you have to push down and twist to get out. Other dead giveaways, the numbers on the side.
T18=1301
T19=1309 The diesel and gas versions have different first gear ratios as well, varying from 4:1 to almost 7:1
NP=has a NP inside of a gear.
Old Oct 27, 2008 | 02:56 PM
85e150's Avatar
85e150
Originally Posted by UTfball68
I could be wrong but...IIRC, the T-18 has reverse over and up, the NP435 is over and down...I believe the T-19 was also over and down for reverse, but I that would have been swapped in.
According to another site which we can't mention...(think fortifications) the NP 435 is over and down for R. As previously noted, aluminum top cover also id's this box.
T 18 from '66 to '78 shift over and up for R, later over and down. They list the T18 from '65-'85. Note the reference of '66 or '65 as a start date, as listed on that site I can't mention. Certainly there are other sources for this info.
T 19 = synchro first, as per prev. post. It also seems both the T19 & 18 were offered side by side for several model years, as they list the T19 from '74 to '88.
Pics here:
Domestic Truck Tranny Guide
As for the 5 speed idea. What do you want, sporty or back 40? You are looking at the NV 4500 for a truck trans:
High Impact - NV4500 5spd
If you want a road-race transmission, you need to think TKO or T56 or other higher capacity trans. Info, transmissions here:
Modern Driveline - T5 / TREMEC TKO Transmission Conversion - Swap your Ford Mustang, Falcon, Cobra, Hotrod into Overdrive! Performance Parts
TTC: TREMEC Transmissions
Good luck.
Old Oct 28, 2008 | 12:41 PM
Alvin in AZ
Originally Posted by 85e150six4mtod
"Borg Warner T18 ...Used in Ford trucks 1956-73..."
Ooops. ;)
My '75 F150 came with the T18 and my buddy's "no bed" '76 F350 did too.
(he made a cattle hauler out of it)
Doggonit, his daughter's '75 F350/460/mush box stock trailer hauler went
belly-up and they put "my;)" 360/T18 in it ...then her truck got stolen and
we've never seen it again. "my spare FE and T18 went south :)"
Alvin in AZ
Old Oct 28, 2008 | 01:21 PM
85e150's Avatar
85e150
Like looks have they dislexia....other all 1965 mentions.
Vean555
15
Jan 16, 2013 09:40 PM
Fordguy_1970
Sep 7, 2010 12:19 AM
Guntar
Feb 8, 2010 09:19 PM
LiftdFord
Jun 13, 2008 08:34 PM
Brown89f150
May 8, 2004 04:32 PM
