drive shafts
Old Oct 27, 2008 | 06:07 AM
F.ROCK's Avatar
F.ROCK
drive shafts
are the drive shafts the same for three speed and 4 speed?
i am installing a 4 speed. also i've been told that the trans mount was the same but it isnt. where to get the 4 speed trans mount?
Old Oct 28, 2008 | 05:03 AM
F.ROCK's Avatar
F.ROCK
anyone???????
Old Oct 28, 2008 | 08:24 AM
bobbytnm's Avatar
bobbytnm
Roast em' if you got 'em
You might get a little better response if you give us some kind of clue what you're working on. Year, make? model? stock? modified?.........anything?
Bobby
Old Oct 28, 2008 | 08:43 AM
LEckart's Avatar
LEckart
Do you mean the same length or the same end connections? Need more info.
Old Oct 28, 2008 | 03:47 PM
F.ROCK's Avatar
F.ROCK
doh! yes i forgot to mention that its a 52 f1!
my old truck has a 3 speed on the column. i have a 4 speed that i'd like to install; will i need to replace or cut the shaft? thanks!
Old Oct 28, 2008 | 06:04 PM
mossyoak1992's Avatar
mossyoak1992
if its a 4spd from a flathead it will bolt right in with stock shaft
mossyoak1992
oh i forgot to say from a f1 with a flathead bigger trucks had diff mounts
Old Oct 28, 2008 | 09:00 PM
F.ROCK's Avatar
F.ROCK
the trans is mounted to an earlier engine, 59ab. the guy i bought it from said it was pulled from a 52 f1. the trans is a top loader w/ the emergency brake attached.
Old Oct 29, 2008 | 06:23 PM
mossyoak1992
yeah youl be fine
