1966 - 1977 Early Broncos
Fuel gauge
Old Oct 26, 2008 | 07:28 PM
JCastellaw's Avatar
JCastellaw
Fuel gauge
I did some work on my 74 bronco's alt and my have screwed up something. My gauge reads full all the time. Any ideas???
Old Oct 27, 2008 | 09:14 PM
dodmort's Avatar
dodmort
maybe fried the voltage resistor on the back of the dash...????
my 69 250 spikes all the time then goes back to norm but it affects all the gages...
Old Oct 28, 2008 | 01:52 PM
76 crew's Avatar
76 crew
x2 on the voltage resistor, especially if you didn't disconnect the batt before doing your electrical work
Old Oct 28, 2008 | 04:01 PM
JCastellaw's Avatar
JCastellaw
where can I get a voltage resistor? If it is fried, would it read full? Is there a way to test it? Anything else fried????
Old Oct 28, 2008 | 05:19 PM
dodmort's Avatar
dodmort
I cannot honestly every say i have had the dash unit all the way out of my EB"S..
but i have on the 250...
LMC had them
were not to hard to find...
cannot say if it is the same as EB to late 60's f-250..
Bet number dummy knows.
I think my f-250 may not have one at all anymore...
have several dashs laying around.
let me look tonite before it gets dark.
if i have extars ill send you one to try..
Old Oct 28, 2008 | 09:14 PM
dodmort's Avatar
dodmort
i do have one.....if it fits
Old Oct 31, 2008 | 02:08 PM
JCastellaw's Avatar
JCastellaw
It pulses up to 1 volt. I am using the gAUGE ON THE DASH. Think the problem could be that my sending unit is not grounded good???
Old Nov 1, 2008 | 07:52 AM
dodmort's Avatar
dodmort
i also found them in the NPD book.
so there are plenty of places to get them if u need them...
Old Nov 1, 2008 | 09:49 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1966/77 Bronco instrument cluster voltage regulator / 1961/66 F100/1100
B9MZ10804C .. ICVR = Instrument Cluster Voltage Regulator (Motorcraft GR508)
Available from Ford: MSRP: $85.40 (ouch!) / FTEpartsguy.com price: $46.12
Application:
1966/77 Bronco / 1961/66 F100/1100 / 1965/66 Mustang / 1960/66 Galaxie & Thunderbird / 1959/66 Lincoln & Mercury / 1960/65 Falcon/Comet / 1962/65 Fairlane/Meteor.
> > Most autoparts stores carry ICVR's, but take the old one with you. < <
1957 thru 1987: There are at least 10 different types.
You never know how reliable autoparts store parts catalogs are, the peeps that work in these stores may not be reliable either.
This ICVR may or may not the problem.
Usually the ICVR, when it fails, causes the temp and gas guage needles to waltz up and down on their own.
Old Nov 2, 2008 | 08:48 PM
JCastellaw's Avatar
JCastellaw
Ouch! That's not cheap!
Old Nov 2, 2008 | 09:47 PM
dodmort's Avatar
dodmort
that is what happens to my 69 250...
but always goes back to norm...
wild needle sweeps....but at least i make gas for a short while...
but my 68 bronco shows full much of the time then when i use a good deal of the gas it starts to read normal...
but..
if it was acting normal then went haywire..something else must be up...
actually my Harley does the same...in reverse..says it is empty yet has 1/3 of fuel left...
Old Nov 2, 2008 | 11:04 PM
JCastellaw's Avatar
JCastellaw
may be it!
Old Nov 3, 2008 | 12:34 AM
NumberDummy
but always goes back to norm...wild needle sweeps.
The ICVR that is used in 1969 is different than the one I typed above.
C6DZ10804A .. ICVR (Motorcraft GR510) / Application: 1968/69 F100/750
DOUBLE OUCH! MSRP: $117.89 / FTEpartsguy.com price: $63.66
Parts store prolly cheaper.
1970/72 is different again.
Old Nov 3, 2008 | 10:36 AM
JCastellaw's Avatar
JCastellaw
O me! Maybe that is not my problem!
Old Nov 3, 2008 | 08:51 PM
dodmort's Avatar
dodmort
ok
go somewhere else...with this.
did 74's have two tanks??
