Sponsored by: Kumho
Front end/Ball joints
Old Dec 17, 2002 | 11:18 PM
rwmcalister's Avatar
rwmcalister
Hi guys. I have a '96 F150 upon which I just replaced the radius arm bushings. The noises from the worn out bushings are gone, but now I hear another odd popping noise occasionally that I can't figure out. It pops sometimes when turning and sometimes when going over a pothole and as nearly as I can tell, it's in the left front somewhere. How do you know when the ball joints need replacing? Is a sagging front end an indicator of that? Any help w/these questions would be greatly appreciated.
RW
Old Dec 18, 2002 | 10:10 AM
pward76's Avatar
pward76
[updated:LAST EDITED ON 18-Dec-02 AT 11:14 AM (EST)]I am certianly no expert, and there should be someone else to either verify or contradict this, but I think a sagging corner is most likely your spring getting tired.
Here is how I diagnose ball joints. Jack up that corner and grab the top and bottom of the wheel. If it wiggles top to bottom, it could be either wheel bearings or ball joints. If there is more than a little movement, get someone to wiggle the wheel while you watch the ball joint, you can see if it moves. If it doesn't, I would suspect bearings.
Make sure the truck is on a solid jack stand. Never get under it with just a jack holding it.
Old Dec 18, 2002 | 11:27 AM
rwmcalister
Thanks for the info, I'll check that out. Has the front end of your '89 ever sagged? Mine is a 4x4, I forgot to mention that.
Old Dec 18, 2002 | 12:34 PM
pward76's Avatar
pward76
No, the 89 has not sagged, nor does the 68, but I'm going to replace those springs as the ride is too mushy for me. I will also be adding a sway bar (or more accuratelt, an ANTI-sway bar). mine is a 4x2
Old Dec 20, 2002 | 05:53 AM
mooktank's Avatar
mooktank
mine was doing that too after i had NEW ball joints put in. It has now stopped
Old Dec 20, 2002 | 05:24 PM
mjb1962's Avatar
mjb1962
