oil pan
Old Oct 26, 2008 | 07:08 PM
Pud12343's Avatar
Pud12343
oil pan
i have a 76 f100, 390, c6 and a quick question. on my oil pan, the drain plug is about an inch above the frame, should it be like this? its almost impossible to change the oil right, because it drains straight on to the frame and plus its extremely hard to get a wrench to it. like always, any help is appreciated!
thanks
Old Oct 26, 2008 | 07:12 PM
fastfarmer's Avatar
fastfarmer
That's the way they came. Just think positive - your crossmember will never rust out.
Old Oct 26, 2008 | 07:15 PM
fmc400's Avatar
fmc400
MSEE
It's a common problem; sometimes changing the oil with the truck on jack stands will give you enough of an angle to prevent this.
Old Oct 26, 2008 | 07:34 PM
Pud12343's Avatar
Pud12343
ok, thanks guys! do they make an oil pan that will move it from above it?
