Sponsored by: Innova
Navigation problem
Old Oct 26, 2008 | 05:56 AM
srad2drag's Avatar
srad2drag
Navigation problem
I'm have a annoying issue with my factory navigation HU. I have a 04 Screw and I purchased a navigation deck from ebay. I installed it and for the most part it does work good. Sometimes though the navigation will get out of synch and have my location incorrect on the map. i'm not talking a few miles either. Its like 40-50 miles sometimes.
When I installed the deck I made sure to put the navigation antennae in the provided slot on the bar behind the radio. The block portion of the antennae I mounted lower using the provided 3m tape.
Shoulded I remove the little block that the antennae is connected to higher? Is there any buttons I can press to make the map home in on my correct location.
This is starting to get alittle annoying if anyone has any info please respond.
Old Oct 26, 2008 | 06:14 AM
glruff's Avatar
glruff
FTE Leadership Emeritus
IDK, but the aftermarket unit I have(Eclipse), I mounted the antenna on the dash for an unobstructed location to the satellites.
Did you try the Ford site for documentation on how to setup the unit?
Old Oct 26, 2008 | 09:00 AM
2000silverbullet's Avatar
2000silverbullet
+1. I don't have your setup, but how would the antenna work if it doesn't have a clear view of the sky (behind the radio sounds like it's inside the dash???)?
Try putting it up on your dash to test the signal strength.
I know when my nav antenna died on my AVIC that it would put me far away on the map from where I was, sometimes in another state.
Old Oct 26, 2008 | 11:40 AM
srad2drag's Avatar
srad2drag
Where is the Ford site located with this documentation?
Old Oct 26, 2008 | 11:42 AM
srad2drag's Avatar
srad2drag
I guess I could try that to see what happens.
Old Oct 31, 2008 | 01:05 AM
srad2drag's Avatar
srad2drag
I went and moved the gps antennae higher on the dash. When I did it the map still looked the same. I also noticed the little gps box with a red line through it too.
So I removed the radio once more and jiggled the antennae connection to the radio. When I did this the map corrected itself and the gps box with the red line through was gone. So it looks like I had a bad connection to the back of the radio with the antennae.
madsonp
Aug 31, 2012 01:26 AM
mvandolson
30
Oct 23, 2009 09:33 AM
