Starter Issues
Old Oct 25, 2008 | 09:16 AM
pcardy's Avatar
pcardy
Starter Issues
I just bought a 1972 F100 Sport Deluxe and replaced the starter, solenoid, and battery. Now my starter wants to stay engaged. Is there anyone that could shed light on my situation?
Old Oct 25, 2008 | 10:11 AM
Redcat Diesel's Avatar
Redcat Diesel
Check the 2 small wires on the starter relay ( solenoid) most likely they were accidently reveresed when you replaced the relay. Installing the wires on the wrong terminals will cause this problem.
Old Oct 25, 2008 | 11:04 AM
pcardy's Avatar
pcardy
I checked those does'nt change anything, You can tap the solenoid and it disengages, should I buy another one?
Old Oct 25, 2008 | 11:22 AM
Redcat Diesel
Yes I suggest another solenoid. It sounds like it may have a bit of solder or something binding the plunger inside. Also make sure it is bolted solidly to clean, nonrusted metal because the mounting bracket is also the ground.
Old Oct 25, 2008 | 11:50 AM
pcardy's Avatar
pcardy
Thanks a million I'm on my way to the parts store(thought I had out grown this) I'll let you know how it turned out
Old Oct 25, 2008 | 02:11 PM
pcardy's Avatar
pcardy
That got it Redcat Thanks
