Ignition testing
Old Oct 24, 2008 | 06:34 PM
56wannabe's Avatar
56wannabe
Ignition testing
Hello people. I have just taken possession of my dream 56. The wiring in it does not look to safe so I have decided to only wire the ignition and starter to see if it runs. I got it running this afternoon but now it won't start. I think that I am not getting any spark. I had previously put in new points, condenser, coil and ballast resistor. I am running from only the battery with no generator, alternator or voltage regulator. If the key is in the on position [not start] should the negative contact on the coil illuminate a test lamp? What areas can I diagnose with only a test light until I get my multi function ohm meter back on Sunday? Thanks for your help. Peter
Old Oct 24, 2008 | 06:44 PM
52 F3's Avatar
52 F3
Turn the engine until the points are open then test for voltage at the points. If you have voltage there then check for a spark from the coil wire to ground when you momentarily make and break contact across the two parts of the points. Just use a screwdriver tip to make momentary contact. If you get a spark but don't get one when it is all assembled and cranking you probably have poor contact at the points. Dirty or burnt contacts. If you have been running it with 12 volts to the coil for very long you might have burnt the point contacts.
Old Oct 24, 2008 | 09:17 PM
bobbytnm's Avatar
bobbytnm
Roast em' if you got 'em
Its not uncommon for the wire from the points to the coil to short out to ground or to break. Check it where it goes into the body of the distributor.
Good luck
Bobby
Old Oct 25, 2008 | 01:05 PM
Julies Cool F1's Avatar
Julies Cool F1
HI 56wannabe!
Welcome to FTE - it's the greatest.
OBTW you are now to be know as 56isme!!!!!
I guess bad wiring is my biggest pet peave - especially since I've seen so much [just plain] BAD wiring used during these restorations.
When youget the gumption, strip all that bad stuff out of there and get back to us. We can walk you through a rewire (that in these trucks was fairly simple and austere) and that will save you a lot of headaches!
Again, welcome and enjoy!!!!
Julie!
bra$$monkey
Jan 20, 2014 01:14 PM
Coverbrooke
Apr 13, 2012 06:54 AM
mntnbikr
53
May 14, 2007 12:18 PM
workingdog
Dec 23, 2005 01:42 PM
DrFord
May 10, 2002 11:23 AM
