Hi - VA
Old Oct 24, 2008 | 04:50 PM
tommy358's Avatar
tommy358
Hi - VA
can u put a e150 axle in a f150?
Old Oct 24, 2008 | 06:41 PM
Ultramagdan's Avatar
Ultramagdan
Hi Tommy!
Should be able to do it but to make sure you can see what others have tried: https://www.ford-trucks.com/forums/forum28/ Be sure to try out your local state chapter to: https://www.ford-trucks.com/forums/forum147/
Old Oct 24, 2008 | 09:37 PM
STROKIN'IT7.3's Avatar
STROKIN'IT7.3
Welcome Tommy! As Dan said, be sure to check out all the forums on here. Feel free to stop in and join the VA chapter! See you around
Old Oct 25, 2008 | 08:27 AM
shorebird's Avatar
shorebird
Welcome to FTE. As to the axle I don't see why not as long as they have the same dimensions ie; mounting locations for shocks and such.
Old Oct 25, 2008 | 10:20 AM
tommy358's Avatar
tommy358
ty u guys the truck was stalling every time u put it in gear and moved 2 or 3 ft after spending a ton in it just by luck unplugged the rabs on the axle and stopped the stalling replaced everything in the abs sys but no luck so got to be the axle.
Beatertruck
New Member Introductions
Sep 12, 2011 03:38 PM
enyce223
Sep 30, 2008 03:16 PM
carl kincy
Mar 27, 2008 09:06 PM
85fordf250HDguy
Nov 15, 2007 06:51 PM
chris_c
Mar 30, 2007 07:02 AM
