Bronco II Ford Bronco II
tail gate fit question
Old Oct 24, 2008 | 04:21 PM
BCTom's Avatar
BCTom
Are the tail gates from all years of Bronco II production interchangeable? From different photos in the gallery it looks the rear of the trucks didn't change when the front end was restyled around 1990.
I borrowed my neighbours trailer to haul some gravel (I think it's a 1&7/8" ball) turns out it needed a two inch ball... so the trailer pops off the ball, bounces up, the safetly chain yanks it down about the same time I brake and the trailer blows out the back window and slices the tail gate in halves.
Good thing the gravel was free!!
Old Oct 24, 2008 | 06:09 PM
danr1's Avatar
danr1
They changed more then the front end in 89, the body is also longer and shorter.
I can post the dimensions for the 89 hatch when my son gets back for ya if that will help, late tonight or in the morning.
I think it will be the same width but somewhat shorter then the earlier models.
IIRC when I measured a 88 and the 89 bodies side by side the 89 was 5 odd inches longer and some 3 inches shorter then the 88.
Old Oct 24, 2008 | 06:30 PM
BCTom's Avatar
BCTom
Thanks dimensions would be great. The local wreckers seem to think they are all the same size.
Do you mean the overal height of the truck is 3 inches shorter when they redesigned? And the overall length from bow to stern is 5 inches longer?
Just to clarify, when I mention the redesign I'm not talking about the Explorer Sport - the two door version of the Explorer.
Thanks
Bull.
Old Oct 24, 2008 | 07:17 PM
danr1's Avatar
danr1
The body only, not from the ground up but only the body's over all height and length was different.
I had both in the driveway, wanted to use the front fender and hood from the 88 on the 89 even thought the style was "older", dead and stripping it for parts. The 88 was dead but had a mint condition front clip on it. I took some measurement to find it would not work. 89 hood longer, fenders longer. My son said "yea, this is a "second generation" and its shorter and longer then the older model" So I too a tape and held it up to it, sure enough it was longer and shorter by about the numbers I posted. Been a while so I may not have the exact right numbers but should be close.
The 89 is lower to the ground as well but the body itself is shorter. They did it in part as an attempt to make it harder to roll over from what I hear. Longer to make for a little better ride.
And yes I'm talking bronco II's "Second generation" 89 and 90, not explorers.
I'll post the measurement of the gate, outside overall height and width when the thing is here again. Not often these days! lol
Old Oct 24, 2008 | 08:23 PM
ncranchero's Avatar
ncranchero
The front end changed in 89 on the Bronco II. The '84-'88 fronts are the same, the '89-'90 front is the same. The rest of the body did not change, dimensionally. The doors will fit from '84-'90. The 1/4 glasses glued in from '84-'85 and were bolt in from '86-'90 but can be interchanged by drilling bolt holes in the '84-'85 bodies. The hatches will fit from '84-'90. I've repaired a dozen or more BR II's from roll overs to rear enders and swapped parts between all years. The '89-'90's look longer due to the front end, which actually has common parts with the '91-'94 Explorer. When it comes to the hatches there were several variations but dimensionally they're the same.
See below:
heated, w/wiper, w/spare carrier
heated, w/o wiper; w/spare carrier
non-heated, movable glass, w/spare carrier
non-heated, fixed glass, w/spare carrier
heated, w/wiper, w/o spare carrier
heated, w/o wiper; w/o spare carrier
non-heated, movable glass, w/o spare carrier
non-heated, fixed glass, w/o spare carrier
Old Oct 24, 2008 | 08:40 PM
BCTom's Avatar
BCTom
Thanks Steve; That sounds more likely, a mid run facelift as opposed to retooling everything.
Old Oct 25, 2008 | 04:12 AM
ncranchero's Avatar
ncranchero
The BR II got a face lift at the same time the Ranger did since the parts there are the same also, including windshield, doors, etc.
Old Oct 25, 2008 | 09:06 AM
danr1's Avatar
danr1
64wx40.5"H, (64" being widest point just over the tail lights)
Now I don't have any older models here to measure again, scrapped. I thought there was some differences in over all body size but as I said its been a while and it could be I just don't remember right.
Post your year/size if you would please.
This page actually lists the second generation taller, no mention of where the differences are. The difference could very well be all in the front end/suspension.
Ford Bronco II - Wikipedia, the free encyclopedia
Anyway if they are all the same in that respect, all the better.
Old Oct 25, 2008 | 11:31 AM
rebocardo's Avatar
rebocardo
Post #5 is correct.
FWIW: Frames are the same except the front frame horns are different on the 1989-1990 for the different style bumpers.
I am "currently" driving a 1988 and have a 1990 that I am scraping. Tailgates are interchangeable as is all the hardware (example glass listed for both years e4Tz-##). Hinges are the same too.
Even though the interior is different in regards to the steering column and dash, all you have to do is unscrew it and it will bolt right into a 1984-1988.
Only question I have about the doors is the window glass looks like it attaches different, but, I should know that in a few more days as I strip it more. Mirror hardware and all that is interchangeable.
Rear quarter windows are the same, seats are the same except the 1990 EB I have, the pass. front slides forward way more then the <- = 1988.
Old Oct 25, 2008 | 07:29 PM
89_Brnko2!!'s Avatar
89_Brnko2!!
man i wish i could find one with a movable rear glass that would be sweet!!! any ideas??
Old Oct 26, 2008 | 12:01 PM
mudslinging79's Avatar
mudslinging79
please!! tell us more bout the moveable glass!
Old Oct 26, 2008 | 02:09 PM
ncranchero's Avatar
ncranchero
It's just an optional swing up glass. It doesn't do anything special.......
Old Oct 28, 2008 | 03:15 PM
rebocardo's Avatar
rebocardo
You can find them in the junk yards around here. Kind of useless because you have to open the tire carrier to open the window so it makes it only 1/2 as useful.
