hard starting
Old Oct 23, 2008 | 08:23 PM
bigbubba87's Avatar
bigbubba87
hard starting
ok i am having problems getting my truck to start after it has set more then 5 hours. since this started i have put one way check valves in the return line and two in the main fuel line one by the motor and one by the filter. none of the return lines on the motor leak nor do the lines. has all new glow plugs and they are working. im all out of ideas as to why it wont start. does it need a new pump? is the pump just wore out and lets fuel bleed back? some days it will crank and crank with and smoke but still wont start even if i let the glow plugs cycle again. and some days it will crank and crank and wont smoke and just fire right up. so i have no idea as to whats wrong with it. any help is appriciated. thanks justin
Old Oct 23, 2008 | 08:49 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Fuel might not be leaking out, but air is leaking in somewhere on the return lines.
Old Oct 25, 2008 | 12:37 AM
ford trans tech's Avatar
ford trans tech
check your battery voltage while cranking
it needs to spin at least 100 rpm to start
dirty cables , internally corroded cables , or just one weak battery is all it takes
Old Oct 25, 2008 | 08:27 AM
bigbubba87's Avatar
bigbubba87
it cranks over fine. is has new batteries that are 1080 ca and 990 cca. the other night i plugged it in and it fired right up the next morning. that would lean more towards the glow plugs but they are all new and are working. so i have no other ideas. anyone else got any? before i swapped the motor it started perfect in the other truck. and started fine in mine then it slowly got worse.
Old Oct 25, 2008 | 11:27 AM
tjc transport's Avatar
tjc transport
i ain't rite
a few things to look at. you say the glow plugs are new. what brand are they??
plugging it in and starting rite up tells us it is a glow plug problem. either your new glow plugs are bad, or the controller is not working properly.
Old Oct 25, 2008 | 12:10 PM
Lazy K's Avatar
Lazy K
How long does your "wait to start" light stay on? When the light goes out and before you turn the key to "start" can you hear the relay clicking?
Old Oct 25, 2008 | 12:56 PM
bigbubba87's Avatar
bigbubba87
i dont remember what brand they are autolite maybe. and the controller on this truck has never clicked after the wait to start light went out. the one on our 89 7.3 does but the one on mine dont
Old Oct 25, 2008 | 01:21 PM
fuzzy1626's Avatar
fuzzy1626
If it's a solid state unit it should go to the after glow cycle when the wait to start light goes out. Could you try swapping the one from the 89?
Old Oct 25, 2008 | 03:29 PM
tjc transport
i ain't rite
if they are autolites, i would suggest you get them out of there pronto, otherwise you will be pulling the heads shortly. autocrap glow plugs burn out almost instantly in fords and then the tips swell up. and alot of the time, you can't get them out without removing the heads.. but the parts stores sell them to you anyway, cause it means repeat business for them.
you should only run MOTORCRAFT/BERU glow plugs in the ford diesels. for your 87, if it has the spade connectors, you will want the ZD-1 glow plugs.
if you have the bullet connector plugs, the part number for them will be ZD-9.
Old Oct 25, 2008 | 10:40 PM
ford trans tech
again check the cranking voltage
plugging the block heater in assists cold starting which can still be caused by a cranking issue
and check the voltage downstream not at the batteries
we see hard starting and no starting issues all the time from bad batteries or bad cables
and just because a battery is new doesnt mean it works
Old Oct 26, 2008 | 07:08 PM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
Wondering if the controller is not working properly. Not getting the glow plugs up to heat temp. On my 93 it clicks 3 times after up to heat.
Old Oct 27, 2008 | 08:42 PM
Fordranchero's Avatar
Fordranchero
My 92 would cycle the light perfectly but it never actually turned the plugs on, later on it stayed on and burned them all out but the light still went out normally.
Old Oct 30, 2008 | 09:25 AM
bigbubba87's Avatar
bigbubba87
il say it has something to do with the gp and controler ive plugged it in every night and it fires right up
Old Oct 30, 2008 | 06:38 PM
rupejosh's Avatar
rupejosh
im not too well knowledged but i would also have to say its the controller i believe you can bypass it,and if that works your controller is junk but i would check all connections running to it a bad ground or a loose wire can cause huge headaches.
Old Oct 30, 2008 | 08:20 PM
Dave Sponaugle
Over near the dip stick, find the engine electrical harness and follow it to where it plugs into the chassis harness.
On one end of the plug there are two large gauge wires.
Inspect the plug carefully looking for signs of over heating.
The large wires are the power supply to the glow plug relay.
If the connector has melted they might not be making contact at all times.
