Heater / AC controls
Old Oct 23, 2008 | 08:10 PM
Ranger GT2's Avatar
Ranger GT2
My 82 F100 truck has good heat but no A/C. The temp control cable works good and adjust the temp. The lower control arm does nothing but turn off the blower in the off postion. Any other postion ( A/C, heat defrost, floor ) functions does nothing. The air only comes out of the defrost vent on the passenger side. The control has vacuum going to it and it has vacumm going to the switch.
Does this sound like I need to replace the control unit? I replaced the heater core today and cleaned out the housing. The truck had sit for quite a while and had mice living in it.
I'm going to the salvage yard this weekend and was going to pick one up.
Old Oct 24, 2008 | 03:59 AM
timcos's Avatar
timcos
Sounds like you may have a vaccuum hose disconnected. Mine did the same thing. There is a control thing that is behind the dash toward the passenger side next to the radio.
While cleaning out my dash I disconnected thos that goes on the driver's side of the control...reconnected it and all worked fine.
Old Oct 24, 2008 | 02:42 PM
Ranger GT2's Avatar
Ranger GT2
I know everything is connected. I just put in a new heater core and made sure everything was hooked back up.
How much vacuum should be going to the under dash controls. I'll try and measure how much is actually going to the controls and post it.
Old Oct 24, 2008 | 05:45 PM
timcos's Avatar
timcos
it is likely a small hose come off...just look...I could also be wring and it is disconnected somewhere else.
Tim
Old Oct 24, 2008 | 06:39 PM
Ranger GT2's Avatar
Ranger GT2
I got it figured out. The vacuum hose was broke were it goes into the A/C housing. Fixed it with a piece of rubber vacuum hose. Everything works now execpt the A/C won't kick on. No voltage to the A/C pump. Have to look into that later. At least all the other control functions work.
Old Oct 24, 2008 | 11:03 PM
Franklin2's Avatar
Franklin2
Find the switch on the accumulator under the hood. Unplug it and short the terminals together, and see if the A/C compressor will run. If it does, then you are low on freon.
Old Oct 25, 2008 | 02:40 AM
Ranger GT2's Avatar
Ranger GT2
Thanks Franklin and Timcos for the help.
I didn't think about the freon being low. I'll try that and see if that works. The truck sat for a long time before I got it. I'm sure the orings in the A/C system are probably shot too. My brother has a vacuum pump for A/C systems he said he could check and see if it had any leaks. Sounds like a summer project.
Old Oct 27, 2008 | 02:59 PM
Ranger GT2's Avatar
Ranger GT2
You were right on the money Franklin. I put a jumper across the connector for the accumaltor and the compressor locked in and started running.
How hard is it to convert to R134? It will be spring before I'd want to do it. Won't need it till then.
Old Oct 27, 2008 | 03:11 PM
timcos's Avatar
timcos
Where is the accumulator?
Tim
Old Oct 27, 2008 | 04:36 PM
Ranger GT2's Avatar
Ranger GT2
It is right in front of the A/C unit. About the size and shape of a 12oz pop can. Should have a/c lines connected to it and a switch with wires attached near it.
