Code Question?
Old Oct 23, 2008 | 02:43 PM
HowieE's Avatar
HowieE
Code Question?
Went for a short run today and my Edge Evolution started flashing an Alert.
This was within the first 1/2 mile and the truck was not even warm. The codes were
0299 T/S charger under boost
1000 More driving required
2262 Turbo boost pressure not detected mechanical.
During this the highest boost pressure I got was 5 lbs and the truck was running weak.
The codes would not reset with the reset function in the edge and the truck remained weak.
There are 40,000 miles on the truck and has run great up until today. The Edge is set at level #1
Any suggestions
Old Oct 24, 2008 | 02:54 PM
HowieE's Avatar
HowieE
Well once I found out that the 2262 code is for a hose disconnected from the MAP I spent the better part of a day locating the MAP only to find everything was fine and once I cleared the codes the truck ran fine.
For those who may have to locate the MAP is located directly on top of the heater core housing on the bottom of a piece of metal held down with 3 #10 nuts. The hose leads about a foot away to the top center of the passenger side manifold.
