Front Spring Replacement
Oct 23, 2008 | 11:47 AM
I'm replacing my front springs tonight. I know it should be easy but I was just wondering if you guys know of any good sets of instructions. I wanna make sure I get the torque specs right and all that happy chit. Thanks.
Oct 23, 2008 | 01:06 PM
Torque specs- about 2.5- 3 grunts while using a 17" breaker bar for the spring bolts, 2 grunts for the u-bolts also using a 17" breaker bar. Unless you've got big 'ol cannons, then reduce by 1 grunt each.
Oct 23, 2008 | 01:08 PM
Now that I understand, haha
Oct 23, 2008 | 03:35 PM
be careful when taking out the bolt in the front hanger on pass side if u hit it 2 hard y can damage your condeser for put the bolt backwards fo some reason lol
Oct 23, 2008 | 04:29 PM
<TABLE cellSpacing=0 cellPadding=3 border=1><CAPTION>This is from the 2003 Workshop Manual
Torque Specifications
</CAPTION><TBODY><TR><TH vAlign=bottom align=middle>Description</TH><TH vAlign=bottom align=middle>Nm</TH><TH vAlign=bottom align=middle>lb-ft</TH></TR><TR><TD vAlign=top align=left>Adjusting Sleeve Clamp Nuts — F-250, F-350, F-450, F-550</TD><TD vAlign=top align=middle>55</TD><TD vAlign=top align=middle>41</TD></TR><TR><TD vAlign=top align=left>Front Spring U-Bolt Nut — F-250, F-350, 4x4 and F-450, F-550</TD><TD vAlign=top align=middle>133</TD><TD vAlign=top align=middle>99</TD></TR><TR><TD vAlign=top align=left>Lower Ball Joint Nut — F-250, F-350, 4x4 and F-450, F-550</TD><TD vAlign=top align=middle><SUP>a</SUP> </TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>Rear Spring U-Bolt Nut — F-250, F-350</TD><TD vAlign=top align=middle>250</TD><TD vAlign=top align=middle>185</TD></TR><TR><TD vAlign=top align=left>Rear Spring U-Bolt Nut — F-450</TD><TD vAlign=top align=middle>300</TD><TD vAlign=top align=middle>222</TD></TR><TR><TD vAlign=top align=left>Rear Spring U-Bolt Nut — F-550</TD><TD vAlign=top align=middle>350</TD><TD vAlign=top align=middle>259</TD></TR><TR><TD vAlign=top align=left>Upper Ball Joint Pinch Bolt — F-250 and F-350, 4x2</TD><TD vAlign=top align=middle>80</TD><TD vAlign=top align=middle>60</TD></TR><TR><TD vAlign=top align=left>Upper Ball Joint Nut — F-250, F-350, 4x4 and F-450, F-550</TD><TD vAlign=top align=middle>125</TD><TD vAlign=top align=middle>93</TD></TR><TR><TD vAlign=top align=left>1/4-Inch Diameter Bolts and Nuts — Grade 5</TD><TD vAlign=top align=middle>12</TD><TD vAlign=top align=middle>9</TD></TR><TR><TD vAlign=top align=left>5/16-Inch Diameter Bolts and Nuts — Grade 5</TD><TD vAlign=top align=middle>20</TD><TD vAlign=top align=middle>15</TD></TR><TR><TD vAlign=top align=left>3/8-Inch Diameter Bolts, U-Bolts and Nuts — Grade 8</TD><TD vAlign=top align=middle>50</TD><TD vAlign=top align=middle>37</TD></TR><TR><TD vAlign=top align=left>7/16-Inch Diameter Bolts, U-Bolts and Nuts — Grade 8</TD><TD vAlign=top align=middle>82</TD><TD vAlign=top align=middle>61</TD></TR><TR><TD vAlign=top align=left>1/2-Inch Diameter Bolts, U-Bolts and Nuts — Grade 8</TD><TD vAlign=top align=middle>122</TD><TD vAlign=top align=middle>90</TD></TR><TR><TD vAlign=top align=left>9/16-Inch Diameter Bolts, U-Bolts and Nuts — Grade 8</TD><TD vAlign=top align=middle>176</TD><TD vAlign=top align=middle>130</TD></TR><TR><TD vAlign=top align=left>5/8-Inch Diameter Bolts, U-Bolts and Nuts — Grade 8</TD><TD vAlign=top align=middle>240</TD><TD vAlign=top align=middle>178</TD></TR><TR><TD vAlign=top align=left>3/4-Inch Diameter Bolts, U-Bolts and Nuts — Grade 8</TD><TD vAlign=top align=middle>350</TD><TD vAlign=top align=middle>259</TD></TR><TR><TD vAlign=top align=left>7/8-Inch Diameter Bolts, U-Bolts and Nuts — Grade 8</TD><TD vAlign=top align=middle>570</TD><TD vAlign=top align=middle>420</TD></TR><TR><TD vAlign=top align=left>1-Inch Diameter Bolts, U-Bolts and Nuts — Grade 5</TD><TD vAlign=top align=middle>860</TD><TD vAlign=top align=middle>634</TD></TR></TBODY></TABLE>
Oct 23, 2008 | 04:34 PM
Nice post Robin!
Adam:
Step 1 call Mike
Step 2 call Ronnie
Step 3 watch them do it as you drink a beer!!!
JK.......Good Luck Brother!!
Oct 23, 2008 | 04:50 PM
Quote:
Originally Posted by
megawatt00
Nice post Robin!
Thanks Jim, just happened to run across that the other day.
Oct 23, 2008 | 06:28 PM
Seems Robin hooked you up good, now thats a spec sheet
As for helping Jim, i think Adam is getting o-rings for his turbo, might do them tomorrow. As for Ronnie, this new job he got he,s prolly
, lol. Just messin bud.
Oct 23, 2008 | 09:34 PM
Haha, I like the way you think Jim.
Oct 23, 2008 | 09:35 PM
Thanks for that chart Robin.
Oct 23, 2008 | 09:37 PM
Adam0331
Thanks Adam. I would kill to have a few of my FTE friends closer to me. It seems that I am the "go to guy" for the people that I know here.
Oct 23, 2008 | 09:42 PM
Hah, yea there are quite a few of us in the area actually.
Oct 23, 2008 | 09:57 PM
I know you lucky B@#$ard!!!
Oct 23, 2008 | 10:03 PM
Oct 23, 2008 | 10:05 PM
No need to be Adam. You, Mike, and Ronnie are fortunate to be close enough to wrench together.
