Sponsored by: Real Truck
tow mirror question
Old Oct 23, 2008 | 11:45 AM
shu5720's Avatar
shu5720
tow mirror question
Hey guys, just installed my tow mirrors. Finally! Love them so far. I did have a question though, do all the mirrors telescope? I was able to get actual Ford mirrors (part #3C3Z17682DAA) in the box for $200. They work and look awesome but seem to be extended all the time (about an 8 inch gap between the mirror the base). Am I missing something?
Old Oct 23, 2008 | 01:11 PM
ReAX's Avatar
ReAX
The ford ones should retract. I keep mine in and there is only about 2" of beam showing between the plastic of the mount and mirror.
Old Oct 23, 2008 | 02:26 PM
shu5720's Avatar
shu5720
Not to sound stupid but, they just push in right? Nothing special I have to do? I'll check again when get home tonight. Thanks
Old Oct 23, 2008 | 02:43 PM
riggz's Avatar
riggz
Yes they push in. They dont retract all the way.
Old Oct 23, 2008 | 03:05 PM
Dsl Lover's Avatar
Dsl Lover
The original tow mirrors on '99 and some '00 f250's do NOT retract. They are out all of the time, just like you describe. Ford made the change later to telescoping mirrors. If your mirrors have some white lines on top of the bottom rails (Where the mirror would slide in), then they are surely telescoping. If they do not (Even early telescoping mirrors did not have the marks), then they may not be telescoping.
Give the outside of the mirror a good hit with the palm of your hand (toward the truck). If it doesn't budge, then it is most likely the fixed kind.
Old Oct 23, 2008 | 03:48 PM
shu5720's Avatar
shu5720
Just gave them a couple of good hits and they didnt move. Oh well. I would have preferred telescoping ones but given they are factory parts, I can live with it. Thanks again.
Old Oct 23, 2008 | 04:09 PM
FTX's Avatar
FTX
According to the part number you gave they are telescoping mirrors and should look like the pic below.
Notice the gap on the arms in this pic which shows them pushed in, yours may already be out, if so try pushing them in. If not try pulling out on them. It sometimes takes a quick jerk, but not enough to pull them off the truck :-)
Old Oct 24, 2008 | 07:22 AM
shu5720's Avatar
shu5720
That's what thought, at least that's how they were advertised. They dont look like that though. The "stalks" are much longer. I bought them from the guys sister so I wonder if these are the take offs and the telescoping ones are on the truck??
Old Oct 24, 2008 | 08:42 AM
Dsl Lover's Avatar
Dsl Lover
They could be NOS (New, but old stock). The telescoping ones aren't much different other than the fact that they telescope and the bottom small mirror is adjustable.
Just be careful when pull up to things (mailboxes, atm's, drive-thru windows, etc.) and you will be just fine. If they were advertised as something that they are not, then that is different altogether.
