Sponsored by: Kumho
Dually tire size max????
Old Jan 10, 2003 | 06:03 AM
acmcc's Avatar
acmcc
Need some advice please:
New truck due any day now, F350 Crew 6.0 PSD 5spd Auto 4X4 4.10 LS DRW, FX4 package.
I have heard that the factory installed Firestone Steeltec 235/85R16E AT's are not so good. I would like to replace them larger better performing / looking tire. In Fla. there is tire shop called "Good Roads" that will buy back new tires with less than 100 miles. So here's the Q's: 1.How large a tire (MAX SIZE) can I replace them with considering the duals spacing? 2. Once the size issue is clear, what brands should I consider? ( I consider my self a mature age 52 with occational flashbacks of age 25. I will be mostly a road warrior with an occational dirt/mudd party. I will potentionally haul a 13,000 lb boat [200 to 1000 miles] up to 5X per year)
Really need your opinions... my heads a spinnin'... THANKS
Old Jan 10, 2003 | 09:23 PM
blownbronco's Avatar
blownbronco
I would say you could fit a 33" tire down there!!
Old Jan 10, 2003 | 10:21 PM
DCSpecial's Avatar
DCSpecial
[updated:LAST EDITED ON 01-10-03 AT 11:30 PM (EST)]I think 255/85/16 would be the max. As for brands some guys like BFG MTs and Michelin. When you look at tires don't only look at the D or E load rating but also look at how many lbs that they can handle, many times it's not a big difference between the two.
Hope this helps.
Old Jan 11, 2003 | 04:41 PM
acmcc's Avatar
acmcc
Thanks for the link and the info ... Really appreciate it.
Old Jan 11, 2003 | 06:42 PM
dk5122's Avatar
dk5122
scozim
Modular V10 (6.8l)
Feb 14, 2017 05:27 PM
shnoop
29
Jan 24, 2017 03:19 PM
Brian1061
Apr 24, 2016 05:25 PM
RedWireUsA
May 6, 2007 05:59 PM
BioBen
Bronco II
Oct 6, 2004 03:07 PM
