C6 Question
Old Oct 22, 2008 | 01:50 AM
Uncle Grumpy's Avatar
Uncle Grumpy
C6 Question
Hi, I am getting different opinions from the "pro's" on my problem, so I came to the experts.
Does a C6 auto make a burning clutch smell when it's bands or clutches are slipping or about to fail? Is it possible for smoke to come from the tranny.
Cheers
Old Oct 22, 2008 | 06:50 AM
jadmt's Avatar
jadmt
mine did not. I lost 3 rd gear and 2nd was about to go. my symtoms where it just would not upshift. No smoke or smell.
Old Oct 22, 2008 | 07:09 AM
jr32560's Avatar
jr32560
I've had a few burn up and never smelled nothing-the fluid will smell burned-the only thing that comes to my mind would be brakes dragging!
Old Oct 22, 2008 | 09:28 AM
alxsnmr's Avatar
alxsnmr
The burning clutch would be from the brakes, the fluid will smell like burned oil if the clutchs are slipping inside it. The C-6 clutchs are constantly bathed in oil unless the tranny has gone dry or the pump quite, then you will get that burned clutch smell and not move in any gear due to loss of friction.
Old Oct 22, 2008 | 09:24 PM
Uncle Grumpy
Thumbs up
Thanks. I will check every thing else first!
