Sponsored by: Real Truck
Front coil springs
Old Oct 21, 2008 | 05:48 PM
northwoodsconst's Avatar
northwoodsconst
Front coil springs
I heard that I can put F-550 springs on my F250 (06 Diesel) and level my truck. Is this true?? And is it a better option than spacers also will I need new front shocks???
Old Oct 21, 2008 | 06:21 PM
Super08's Avatar
Super08
There are several springs you can put on. I installed 6000lb springs on mine. It was because it was bottoming out with the stock 5200lb springs. You can also get 6500lb and 7000lb springs. I wasn't interested in raising the front, but the change did raise it 3/4". Much more of a change than that and you will start to run into situations where you may need to correct your castor and re-center the steering wheel.
Old Oct 21, 2008 | 07:07 PM
DCSpecial's Avatar
DCSpecial
I'll be able to tell you tomorrow how much if any the 7000lb coils (450/550 coils) rasied my F-350 compared to the 6000lb coils that came on it.
Went with the coils, Bilstein shocks, Icon adj. trac bar and Icon caster cams.
Old Oct 22, 2008 | 07:15 PM
DCSpecial's Avatar
DCSpecial
The 7000lb coils raised my truck approx 3/4" over the 6000lb coils.
Old Dec 29, 2008 | 01:27 PM
John7894's Avatar
John7894
How do you guys know what the rating is on the springs, 6K, 7K, 5200K, etc... Did certain ones come on certain trucks or is there a chart somewhere I need?
I need to raise my 2wd in the front. The factory springs are worn out after 314,000 miles of driving. The truck sits low and regularly hits the bumpstops. I'd like to raise it and level it out if possible.
Thanks
Old Dec 29, 2008 | 03:07 PM
LOOnatic's Avatar
LOOnatic
Thanks
Hey John i have the same problem and live in New Orleans.
Check your PM's
Old Dec 29, 2008 | 07:20 PM
Furian's Avatar
Furian
You Keep What You Kill
Thanks
I'd like to know that as well... I have a 2005 F350 with Trailer Towing, Camper, and Snowplow Packages, if that helps.
Thanks!
Old Dec 29, 2008 | 07:29 PM
DCSpecial's Avatar
DCSpecial
You can look on the door tag that's on the driver's side door jamb.
Look for "Front GAWR".....that will tell you what springs you currently have.
Old Dec 29, 2008 | 07:32 PM
Super08's Avatar
Super08
The springs have a code on them marked on a tag.
5C3Z-5310-FA (4800 lb SPRING)
5C3Z-5310-EA (5200 lb SPRING)
5C3Z-5310-DA (5600 lb SPRING)
5C3Z-5310-CA (6000 lb SPRING)
5C3Z-5310-BA (6500 lb SPRING)
5C3Z-5310-AA (7000 lb SPRING)
My 07 came stock with EA springs which I had changed to CA to solve problems with the from end bottoming out.
My new 09 came with CA springs from the factory. Even though it is a heavier truck I haven't had any problems with the front end hitting the bump stops like my 07 did.
Old Dec 29, 2008 | 07:52 PM
akford351's Avatar
akford351
I went from 5200 to 6000lb ones and gained about .75"... ride was much better also.
Old Dec 29, 2008 | 09:37 PM
John7894's Avatar
John7894
Thanks Super08,
That's what I was looking for! Gonna track down a set tomorrow.
Anybody running the 6500lbs ratings? Wonder how they would do ride wise. I don't think they'd raise it more than 3/4" as well.
Old Dec 29, 2008 | 09:54 PM
Super08's Avatar
Super08
John the part numbers I listed are for the 2005 and up 4wd trucks. They may or may not be the same for the coils on the 2wd trucks. I would look into it first before putting your money out on anything.
Doug
Old Dec 29, 2008 | 11:09 PM
John7894's Avatar
John7894
Thanks, I'll double check those numbers.
Old Dec 30, 2008 | 10:29 PM
Furian's Avatar
Furian
I have 5,200 coil springs in front and 7,000 leaf springs in the rear.
Old Dec 30, 2008 | 11:30 PM
Stewart_H's Avatar
Stewart_H
For you guys who went with an upgraded spring, did you have to get a new shock because of the 3/4" lift the new spring gave?
Stewart
