Sponsored by: Real Truck
Door lock problem
Old Oct 21, 2008 | 12:06 PM
Nate4.2's Avatar
Nate4.2
Door lock problem
Ok i have a 99 f250 super duty the door acctuator on the passenger side has stoped working. I am going to replace it dose anybody have any comments or suggestons on taking it off the truck im kinda stumpep. any help would be greattly appreciated!!!
Old Oct 21, 2008 | 12:08 PM
Todd316's Avatar
Todd316
If it was anything like my mustang all you have to do it drill out the rivets and use new rivets to reinstall. Very easy.
Old Oct 21, 2008 | 12:58 PM
F350-6's Avatar
F350-6
Have you already bought the new actuator? You can fix the old one with a piece of tin foil.
https://www.ford-trucks.com/forums/4...cks-fixed.html
How far along are you in trying to remove it. Maybe I can offer some advice.
Old Oct 21, 2008 | 01:04 PM
Nate4.2's Avatar
Nate4.2
no i havent bought the new one yeat but i have heard about the alluminun trick but didnt know if it would really work or not.
Old Oct 21, 2008 | 01:13 PM
F350-6's Avatar
F350-6
I just did 3 of the 4 doors on my wife's 01 F250 last weekend. Works like a charm.
Old Oct 21, 2008 | 02:04 PM
Nate4.2's Avatar
Nate4.2
Sweet ill give that a shot!!!
Old Oct 21, 2008 | 02:10 PM
Nate4.2's Avatar
Nate4.2
i have only gotten as far as taking the door panel off and locating the actuator and the locking mecinisim. but i didnt know it was all rivited in there. is that very complecated to drill them out and what size drill do i use?
Old Oct 21, 2008 | 05:22 PM
F350-6's Avatar
F350-6
I undid the rods that connect to the latch assembly, unbolted the door handle and pulled it out (for better access), then removed the torx screws holding the latch to the door. You can then snake the latch assembly (leave the lock cable connected) over in front of the access hole. The actuator has a little plastic locking lever that you pry up and it will slide off the latch assembly. You'll need to unplug the wiring first, and hold it just right to slide past the one of the wiring connection points.
There are 2 rivets that help hold the actuator together. I used a #30 drill bit, which is just a hair larger than 1/8". You could probably get by with a 1/8" bit. Then just pry the thing apart, take apart the motor to get access to the little square thing that needs to be wrapped in foil, and put things back together as outlined in the thread I posted earlier. If you read through the thread there are pictures in there that show you what needs to be done.
If that doesn't make sense, or you have more questions, let me know.
