351-400M AC bracket/compressor options? - AZ
Old Oct 21, 2008 | 05:40 AM
muladesigns1's Avatar
muladesigns1
hi everyone.
I am in the process of restoring a 79 F150 4x4 flairside.
and can use a little guidance.
I rebuilt the 400M, and was wondering if there was a way of installing a more modern compressor and a nicer looking, lighter weight bracket for it as well.
i am going to be running the truck in the desert here in AZ and want to lighten it up as much as I can.
The battery is being moved to the right rear, under the bed, between the frame rails, the intake and heads are aluminum and help, but the compressor is HUGE! and HEAVY! as is the 5lb. bracket!
found out the AC is dealer installed, NOT factory installed. (bracket looks home made). does anyone know what the factory style bracket looks like? or where it can be found?
AC is converted to R134
Old Oct 21, 2008 | 06:57 AM
Ultramagdan's Avatar
Ultramagdan
Hello!
Try posting your question here: https://www.ford-trucks.com/forums/forum38/ There are a lot of folks in that one that can help you out. You can also use your state chapter as a source for wheelin in your state: https://www.ford-trucks.com/forums/forum80/
Checkout the forums and enjoy the site!
Old Oct 21, 2008 | 10:02 AM
muladesigns1
Thanks!
this is my 5th ford truck 2 early broncos 3 77-79 f150 4x4's
there built like no other!
alwaysempty
New Member Introductions
Apr 18, 2013 03:42 PM
Emiliojr
Mar 25, 2008 05:16 PM
85F150302HO
Mar 16, 2008 09:43 AM
phatkat
Jan 12, 2008 08:48 PM
evilwayz7
Sep 4, 2007 06:00 PM
