Speedometer Cluster Switchout
Old Oct 20, 2008 | 10:24 PM
propaneman's Avatar
propaneman
Is it possible to put a 03-06 speedometer cluster in a 2002 Excursion? My cluster has the actual numbers that switch over and the kind of cluster I want to put in is digital. Has anyone done this and had it work for them?
Thanks
Billy
Old Oct 20, 2008 | 11:16 PM
bdrummonds's Avatar
bdrummonds
IDK about this one, but Ill give you a bump
Old Oct 20, 2008 | 11:33 PM
superduty4x4's Avatar
superduty4x4
It will probably work, but may require swapping out the internal harness as well. I've not torn into an SD dash, but on the OBS trucks there were small differences in wiring among the years so you have to have a cluster from the same year rig when you swap or you get weird stuff going on like high beam indicator on all the time.
