Something in the Engine Let go...
Had my slick loaded down and driving a good distance on the highway this weekend, doing about 60-65 mph the whole way when I heard a somewhat loud "crack!" and what sounded like a coupe of peices rattling around for a second afterward. The truck still ran fine, but I pulled off at the next exit and when I came to a stop the engine was running really rough (like it had a miss). I shut her down and did a visual check, everything seemed to be in order. I was 100 miles from home and 70 miles from where I had to go, So I said hell with it, fired it back up and kept going. I managed to get her to my destination, although I had to listen to a sickening "slapping" sound from the valvetrain the whole way. Sounded like a real bad exhaust leak, as it only made noise under load. The sound never got worse, even though I had to keep going another 70 miles.
I took the valve covers off and all the rocker arms/push rods were all tight. I cranked the engine over a few times with the coil disconnected and everything is getting oil and moving like it should, all parts were in tact. I fired it up with the covers off and it wasn't making that slapping noise, but still had the miss (sound came back when I put the covers back on). I pulled a few plug wires off and found that the miss is coming from the driver front cylinder, the same one the noise is coming from (not sure which number that one is), although it is still getting spark. I had limited tools with me so I didn't take anything else apart. I had to leave it at my destination this weekend until I can get back down there to fix it. I suspect maybe a lifter is busted or something?? Not sure, but I don't think these are hydraulic lifters are they? Anyone have any ideas what I'm facing here?
Sorry for the length, just wanted to make sure I had all the details in there.
Don't forget: You can go over to Green Sales if you need illustrations of the internal engine parts.
Talk to Dave, he's the most experienced guy they have, and knows these engines.
