No Spark please help
Old Oct 19, 2008 | 04:22 PM
fordmonn's Avatar
fordmonn
Hey all,
Ive listed this in both 87-96 & 80-86
I'm hoping someone can help me. My son blew his motor (302 carb, Duraspk2) in his 86 f250 (motor was changed before he bought it and ran good) this time he put #4 & #8 connecting rods through side of oil pan! "LEAD FOOT" takes after his mom!
We bought a 93 F-150 w/302 efi w/tfi-iv, swapped everything over carb,manifold etc. Went to change dist. and the duraspark dist. is to short so we put the other dist. back in, side plugs on dist. are different one from blown motor has 3 wires orange,purple and black. new on has 7 wires. greens grays and black. has old skool coil, have power to coil motor cranks nice and strong but have no spark from coil to cap (have a spark tool) I know the side plugs don't fit and are probably the problem. I've checked my Haynes manual but of course they don't cover swapping over dist. Do I have to cut and splice wires and if so which ones.
Any help would be much appreciated as I'm pulling my hair out!
Thanks!
Fordmonn
Old Oct 19, 2008 | 05:57 PM
lisagoud's Avatar
lisagoud
there are differences in the 5.0's on the fireing order as well as injector sequesnce.
Home:Engine Specs:Ford 302-HO, 351W
Ford V8
302-HO(5.0L), 351W(5.8L)
(302-HO from 1985 on)
Firing Order
Cylinder Numbering Distributor Rotation
Rotor Under Cap Spins:
Counter
Clockwise
Torque Specs
always torque bolts in three equal increments
Bolts or Parts Lube or Sealer Torque to:
Main Caps Engine Oil 105 ft-lbs.
Connecting Rod Bolts
Engine Oil 45 ft-lbs.
Cylinder Heads 351W
Engine oil (blind holes)
Sealant (water jackets)
85 ft-lbs.
Cylinder Heads 302 HO
Shorter Bolts
Longer Bolts
Engine Oil (blind holes)
75 ft-lbs.
85 ft-lbs.
Rocker Arms Engine Oil 20 ft-lbs.
Oil Pump Engine Oil 25 ft-lbs.
Oil Pump Pick-up Thread Locker 20 ft-lbs.
Oil Pan Engine Oil 15 ft-lbs.
Camshaft Thrust Plate Thread Locker 10 ft-lbs.
Cam Bolt (upper gear) Thread Locker 40 ft-lbs.
Front Cover Engine Oil 25 ft-lbs.
Intake Manifold
(Cast Iron Heads)
Non- Hardening Sealer 25 ft-lbs.
Valve Cover Engine Oil 10 ft-lbs.
Flexplate (Automatic)
Flywheel (Clutch)
Thread Locker 85 ft-lbs.
Clutch Pressure Plate Thread Locker 35 ft-lbs.
Centerbolt
(Harmonic Damper)
Thread Locker 90 ft-lbs.
Bellhousing
(Transmission to Block)
Old Oct 19, 2008 | 08:48 PM
95F350XL's Avatar
95F350XL
Can you swap whats in the old dizzy to the new dizzy? You just have to figure out what wires will sig the coil from the efi dizzy.
Old Nov 9, 2008 | 05:02 PM
fordmonn's Avatar
fordmonn
Hey Guys,
Sorry for getting back so late. between work and everything else time just flys by. I fix the problem! I bought a ford HEI dizzy (Ebay $50) with one wire hook up and she purrrrrrs like a cat.
Thanks for all the imput and advise!!
Fordmonn
clrose99
Apr 12, 2020 11:17 AM
Links_vette
Nebraska Chapter
26
Feb 25, 2009 10:00 PM
LincolnJames
Engine Swaps
Sep 22, 2006 04:46 AM
Tan85
Jun 19, 2005 10:36 AM
