Offroad & 4x4
Ford 9"
Old Dec 31, 1999 | 10:25 AM
Jim_1's Avatar
Jim_1
Ford 9"
I have located a '75 Ford bronco 9" rearend. Was this a good year for these axles? The axle is rated at 2900 lb.
Old Jan 1, 2000 | 11:53 PM
Trail_Rider's Avatar
Trail_Rider
Ford 9"
I personally have never heard of a bad 9" no matter the year. The only problem I've ever heard of and this goes with anything is having them wear out. Good Luck.
Trail Rider
Old Jan 4, 2000 | 09:22 AM
Bill Martin
Guest
Posts: n/a
Ford 9"
It depends on your application. The early Bronco (Pre 78) has a narrower track than the fullsize pickups. My '77 F150 4wd has a nine inch rear rated at ~3600 lbs. My '77 F150 2wd has a ~3200 lb 9 inch. The axels are visually the same but the axel shaft is bigger in the 3600. Also the 3600 uses 3 inch wide leaf springs while the 2wd has 2.5 inch leafs.
Old Jan 5, 2000 | 07:35 PM
Trail_Rider
Ford 9"
dpoc
1978 - 1996 Big Bronco
Jan 15, 2016 10:41 PM
Opossum
1997 - 2003 F150
Apr 11, 2009 05:14 AM
detroitford
Apr 13, 2004 01:39 AM
64_f100_owner
Mar 3, 2004 08:40 AM
