Bronco II Ford Bronco II
Tire Size question
Old Oct 18, 2008 | 08:18 PM
89_Brnko2!!'s Avatar
89_Brnko2!!
Tire Size question
my 89 bronco 2 has 235-75-15`s on it now im wanting to get something a little wider in the same height as what i have now.How close is a 30x9.5x15 sized tire,and how close is a 265-70-15?? im not to good with tire sizes!
Old Oct 18, 2008 | 08:21 PM
89_Brnko2!!
also im looking at getting the Mickey Thompson classic 2 wheels what offset do i need??
Old Oct 19, 2008 | 12:59 PM
mudslinging79's Avatar
mudslinging79
a 235 is bout a 28.8 from what the tire shop tells me. im looking at getting 29s myself, forgot the width of them, but a 265 i think is about a 35 inch or close to it.
Old Oct 19, 2008 | 03:29 PM
danr1's Avatar
danr1
235-75
Maybe this will help some, first number is the tread width...... well rather then try and explain/type it all myself. Read here, tell you all about them numbers in simple terms and how to convert to inches,
Tire Tech Information - A Guide to Tire Sizes
Old Oct 19, 2008 | 04:35 PM
YoGeorge's Avatar
YoGeorge
The standard wider replacement for a 235/75x15 is a 255/70x15. It's virtually the identical diameter, maybe a tenth of an inch larger tops. And almost a full inch wider.
The 30x9.5 will be 1/2-3/4" taller but NOT wider; the 265/70 will definitely be wider and maybe 1/2-3/4 inch taller. The 255/70 is what everyone used to change their trucks and vans to when the 235/75 was the 1/2 ton standard. (I ran them on an old pickup and 3 vans that I've owned during the years).
George
Old Oct 19, 2008 | 08:38 PM
89_Brnko2!!
alright sweet 255/70/15 sounds like the winner,now how about the rims?? im gonna go with an 8 inch rim but what about backspacing and offset??
