mottor bog problems
Old Oct 18, 2008 | 07:08 PM
f250man96's Avatar
f250man96
mottor bog problems
i have a 1996 F250 with 7.3 turbo diesel i have 190000 miles. the problem has evolved from having a hard time cranking it cold to wear now it takes A shot of either and hold the peddle to da floor. the truck smokes white like fuel so bad toware poeple actually think my house is on fire. itll rev to about 2grand then the motor will stall for a second and then ittle ruv up all the way.it has fresh deisel and new o rings on the injectors and a new fuel filter besides that, thats all i have done to it. any sugestions would help thanks
Old Oct 18, 2008 | 07:33 PM
250turbo's Avatar
250turbo
glow plugs & g.p. relay
kurt
Old Oct 18, 2008 | 07:39 PM
ron86toy's Avatar
ron86toy
Ether is not kind to these motors......wd40 will work and not do damage
I agree...test your glow plugs
Follow this instruction.this is for a '99+ so the relay is in different spot
To check the Glow Plug Relay (GPR)
· Be sure the engine is cold, so that the PCM will tell the GPR to turn on. If the engine is hot, you won’t have as much time to check.
· Locate the GPR – Its behind the fuel filter on top of the engine, a little bit toward the passenger side of the valley. There may be two relays there. If so, the rear one is the GPR. It will have two fairly large wires (yellow and brown) connected to one of the large posts.
· With your multitmeter set to DC volts, and 15 V range (if not autoranging), clip the positive (red) lead to the output terminal (with yellow and brown wires connected), and the negative (black) lead to a good ground point (like the battery ground terminal or someplace metal directly on the engine block.)
· Turn the key to ON (do not start)
· If your GPR is good, it should click, and you’ll see 11 volts or so on your meter, then, depending on temperature, it will click off up to 2 minutes later. You should do this a couple of times to make sure it consistently makes the connection.
· If you don’t get voltage with this test, confirm by retesting as follows.
· Remove the two small wires from the smaller two of the four GPR terminals.
· With jumper wires, apply voltage from the battery across the two small terminals. If your voltmeter now reads voltage on the output terminal, your GPR is OK, and your problem is in the PCM circuit that tells the GPR to activate.
To check Glow Plugs.(again for a 99+...there are 2 connectors on the VC for ours)
· Remove the electrical connector on the inboard side of valve cover at the gasket. Press down on the top of the connector latch and pry gently with a screwdriver.
Disconnecting VC harness connector..
· There will be 9 pins on the valve cover gasket where you removed the connector. The two pins furthest forward and the two pins furthest back are for your glow plugs.
· With your multimeter set to resistance (ohms) and low range (single digits) if not autoranging, clip the negative (black) lead to a good ground point.
· Probe each of the 4 outer pins individually with the positive (red) lead, noting the resistance. Good glow plugs will have a resistance between 0.6 and 2 ohms. If you get infinite resistance on any glow plug, that one is either bad or the connector under the valve cover has come loose.
Old Oct 18, 2008 | 07:51 PM
f250man96's Avatar
f250man96
even after then motor has ran and warmed up the glow plugs and relays will cause this? also after warms up its even harder to get 2 get started
Old Oct 18, 2008 | 07:55 PM
ron86toy's Avatar
ron86toy
IPR orings....oil level full?
Old Oct 18, 2008 | 07:57 PM
f250man96's Avatar
f250man96
yea where are the IPR o rings at im new to diesels sorry
Old Oct 18, 2008 | 08:03 PM
ron86toy's Avatar
ron86toy
link
New Page 0
