Offroad & 4x4
Transfer Case.
Old Jan 20, 2000 | 12:16 AM
Boss_358's Avatar
Boss_358
Transfer Case.
Old Jan 30, 2000 | 03:15 PM
Brady's Avatar
Brady
Transfer Case.
I have a NP-205 transfer case, and my shift **** has Lo, Lock-N- Hi, Lock. Are Lo Lock, and Hi Lock one gear? Or are they seperate gears such as Lo, Lolock, Hi, and HiLock. I have locking Hubs, and I didnt understand the shift ****.The truck is a 1976 f-100.
Old Jan 30, 2000 | 04:23 PM
chilly460's Avatar
chilly460
Transfer Case.
Either you have the wrong shift ****, or you don't really have an NP205. 205's didn't have a "LOCK" feature like you're describing on the ****, but the NP203 did. Check the transfer case for a metal tag identifying the model number. Also, the 203 usually came on auto. equipped trucks.
Old Jan 30, 2000 | 06:36 PM
Brady's Avatar
Brady
Transfer Case.
No, I checked the tag, and it is a np-205. Maybe the shifter **** is not the right one. So the 205 has only 4 high, 4 low, N, and 2 high. How do they go in order from the dash back. As in 4 low, N, 4 high, 2 high. So I know what to put the transfer case when it is in 2 wheel drive. Thanks...
Old Jan 30, 2000 | 06:40 PM
Trail_Rider's Avatar
Trail_Rider
Transfer Case.
I suggest you take in out in the gravel/dirt and play with it until you get it figured out. Hi and Low shouldn't be a problem. It also gives you an excuse to go play in the dirt.
Trail Rider
Old Jan 31, 2000 | 06:40 AM
Chuck P.'s Avatar
Chuck P.
Transfer Case.
From the dash-forward most position is 4-Low, next is neutral, then 2-Hi and the whole way towards the seat is 4-Hi. Chuck P.
