weird question
Old Oct 18, 2008 | 02:51 PM
83 F-150's Avatar
83 F-150
weird question
i was looking for the numbers on my engine today and found E7TE-CA ive looked it up on here and what i have read says that it is a 5.0 HO motor that should use the 351 firing order... now for the odd part i have it set up with the normal 302 firing order and it still runs white smoke comes out from everywhere but it does run
also i pulled the driver side valve cover and the only number i could see on the head is 6D25 and the e7te-ca was on the block on the drivers side by the lowest point where the trans bolts to the motor
any help is appreciated
thnx
Old Oct 18, 2008 | 02:57 PM
83 F-150's Avatar
83 F-150
also this motor has a mechanical fuel pump if that helps any
Old Oct 18, 2008 | 10:29 PM
Conanski's Avatar
Conanski
There's no way to tell what motor you have from those casting numbers, that only tells you it's from a casting that was first produced in 1987 so you know it's not the trucks original motor. All small block windsor motors can use cams with both HO and non-HO firing orders so that too doesn't tell you anything. If the intake is about 9" wide then you know you have a 302/5.0, but that's about all you'll know for sure without taking it all apart.
Old Oct 18, 2008 | 11:18 PM
83 F-150's Avatar
83 F-150
what would i need to take apart to tell what kind of motor it is because while it runs it does miss but i cant tell whats causing it i know that the rotor in the distributer is bad but i still dont think that could be and why would the motor smoke from everywhere
Old Oct 19, 2008 | 06:43 AM
MBDiagMan's Avatar
MBDiagMan
If it misses, have you tried the 302 firing order?
Old Oct 19, 2008 | 12:45 PM
83 F-150's Avatar
83 F-150
thats what its runnin with now ill switch the firing order to the 351 when i get the new cap and rotor
Old Oct 19, 2008 | 09:58 PM
83 F-150's Avatar
83 F-150
i went outside and it runs on the 302 firing order
