I recently purchased a set of headers for my 90 F150, 4x4, auto, 302 extended cab.
I havent installed them yet, Im going to build the exhaust myself, but I'm trying to figure out how the pipes will be routed around the transfer case. It seems there isnt a whole lot of room on the drivers side. I originally intended to run true dual exhaust but stuck at the planning stage here.
Anyone have a photo of their truck exhaust you could post?
Most everyone runs the exhaust down the passenger side then split it off at the rear axle for true duals you would do the same. I have a SC 4x2 dual tanks and plan to run it like the Lightning set up.
Yeah you have to route both pipes down passeneger side then split after rear axle most trucks are like that from what I have seen cause of the gas tank and drive shaft
