Big Block Blues
Old Oct 17, 2008 | 01:12 AM
SuperBeaner's Avatar
SuperBeaner
Big Block Blues
Ive got a 390 big block. id rather have a 302 smallblock. Im in the DFW, Texas area....anyone have any HELPFUL suggestions?
Old Oct 17, 2008 | 05:57 AM
f150v602's Avatar
f150v602
try ebay. or find a doner truck with a 302 and get it rebuilt. and i know ive seen crate 302's and there not real expensive.
Old Oct 17, 2008 | 09:55 AM
fastmover's Avatar
fastmover
Craigslist sometimes has good finds.
Old Oct 17, 2008 | 03:10 PM
SuperBeaner
Thanks. The whole 9-10 MPG doesnt really work for me, especially considering this is my daily now that the weather is going to start getting cold.
Old Oct 17, 2008 | 04:52 PM
jowilker's Avatar
jowilker
Cuz, These ol pickups don't make good daily drivers, you can spend a lot of money swapping in a tranny/engine and wont pick up many mpgs.
Get a cheep car to run and keep the truck for what ever. Mine sits in the yard until I need it. My Taurus is my daily driver.
John
Old Oct 17, 2008 | 05:54 PM
blue68f100's Avatar
blue68f100
If you have a good strong 390, you can swap the differential to a 2.75-3.25 ratio, should get you into the 13-15mpg range vs 8-10 for a 360. A 302 may not gain any mpg due to heavy weight of the PU infact may loose some.
And like jowilker suggest find you a small cheap car to drive.
Old Oct 17, 2008 | 06:09 PM
J Hodges's Avatar
J Hodges
I have a 390 in my 69 F-100 that gets about 10mpg. The 302 in my 76 got about 11-12. A 302 is definately not a good gas mileage motor in a heavy truck.
Old Oct 17, 2008 | 08:53 PM
Danger_Dave's Avatar
Danger_Dave
an old gas guzzilng ford truck is something to be enjoyed, and its best to drive it while your enjoying yourself. not commuting 30 minutes to and from work everyday. for that you gotta get a bike or a little riceburner car. gotta have the right tool for the job.
Old Oct 17, 2008 | 11:21 PM
SuperBeaner
ive got a little 883 Harley, im just using the truck for my winter/rain ride. and this was SUPPOSED to be my cheap, economical ride. i mean, i only paid 600 bones for it. i didnt expect it to get 50 mpg, but mebbe 15 would be nice. guess i should have done more research....mebbe i should ask for a raise. you think mebbe an automatic would help? different gearing in the rearend and such? mebbe a 351 instead of the 390? fact of the matter is, im stuck with this truck. gotta make the most,you know?
Old Oct 17, 2008 | 11:34 PM
hunkajunk68's Avatar
hunkajunk68
id keep 390 if its good never make back the money for another engine easy on gas pedal and maybe get the gears out of big galaxy etc
Old Oct 18, 2008 | 12:33 AM
85e150's Avatar
85e150
No advantage 351 vs. 390 unless you do the OD thing and a few other tweeks.
Your diff should be a 9" Ford with a drop-out carrier. There may be a ratio tag on one of the studs holding the carrier into the housing. Look at about 5 o'clock, but it could be anywhere or missing.
You may have a 3.25 axle.
If you do, and if you have 235/75x15 tires at 29 inch diameter, then you are turning about 2450 rpm a 65.
Change to a 2.75 ratio, you'd be pretty tall in the low gears, but your 390 would handle it ok, and you'd reduce your cruise rpm to 2071 at 65....
Used gears $99:
Currie Enterprises Racing Rear End Categories
Calculate for yourself with different tires/gears:
Novak Conversions - Gearing & Gearing Math for Jeeps
In the mean time, go over your fuel system and check for leaks. Especially your carb--if it is the old vented type, they lose gas when the truck is turned off and parked.
There are some ways to save gas here, but fewer ways to save money.
Good luck with it.
Old Oct 18, 2008 | 06:47 AM
Kujo's Avatar
Kujo
Find a 6 cyl truck. I got 17mpg outa mine! I found this 69 f100 in a neighbor's back yard, 300/I6/auto for 300 bucks. The tag is to far gone to see what gears it has....they are TALL though....
Old Oct 18, 2008 | 07:22 AM
jowilker's Avatar
jowilker
NO no & no, for a good ol truck you made a great choice, for an ecno ride you totally missed the mark.
Basically there is nothing that you can swap in that will recover the cost of doing so under 25 years of use. IMHO
The raise thing might be helpful.
John
Ramlock
52
May 2, 2017 03:05 AM
LibTimothy
Texas Chapter
Jan 14, 2015 11:16 PM
Stroker Ace
Dec 10, 2007 10:42 PM
634x4nut
Jun 17, 2006 01:12 PM
ramtoo
Aug 19, 2005 02:14 PM
