The best in all words!!!
Hi!I know I'm in a Ford site,but,don't be a brand loyal,be honest - what is the best built quality pickup,I mean just truck itself,I know Cummins is the best engine,hands down.I mean just truck itself,best quality,front rear axle,suspension,frame,purts,ride,longevity etc.Thanks for replay!
<!-- / message --> <!-- sig --> __________________
I personally feel Dodge is extremely cheap. Just do the door test...close a Dodge door and close a Ford door, which one sounds more sound to you. I know that's goofy, but I can't really relay what I'm trying to say. Never been in a Chevy newer than an '85 so I can't speak of them. So I guess for me Ford is the only way to go.
Hello all...here is a question for anyone. Is there anything I can do to make an '05 6.0 powerstroke last (besides not drive it)? I have an '05 F350 Lariet dualy with 42,000 miles. It needed an engine at 16,000, a steering box at 20, a steering pump at 24k, ball joints at 32k...what's next. If I decide to keep this truck what can I do to make it last..or should I by a Dodge or Chevy? I every now and then pull a 7k lb. horse trailer.
thanks
thanks
atleast the door problem isnt as bad as the 88 and older chevy trucks. i mean you literally have to slam the door to just close it properly. to be honest, i consider ford or a dodge truck because they have solid front axles on 3/4 and 1 ton trucks. both offer a powerful power plant. i sorta dont care about little issues. i just care about funtionality and what it can do for me.
"Hello all...here is a question for anyone. Is there anything I can do to make an '05 6.0 powerstroke last (besides not drive it)? I have an '05 F350 Lariet dualy with 42,000 miles. It needed an engine at 16,000, a steering box at 20, a steering pump at 24k, ball joints at 32k...what's next. If I decide to keep this truck what can I do to make it last..or should I by a Dodge or Chevy? I every now and then pull a 7k lb. horse trailer.
thanks"
You may have a lemon, but a new power steering box, then pump, after a new engine? heres a tip, when making sharp turns, dont crank the wheel completly over, let off about a 1/4 inch, saves the pump. Ball joints and bearings, quit jumping the truck.
and what are you driving an F350 if you only pull a 7k trailer once in a while? my 94 F150 has pulled twice that weight, and sees 7k on a daily basis
thanks"
Hand Clutch
1999 to 2016 Super Duty
13
03-05-2012 07:35 PM
Boomer23059
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
18
07-25-2011 07:12 PM
humboldtps
08-23-2006 02:54 PM
