Next Problem ???
Old Oct 16, 2008 | 10:42 AM
tinker934's Avatar
tinker934
Unhappy Next Problem ???
well im have a delma my ABS light is on (no speedo, and the light on the shifter is flashing ) i changed the sensor in the rear houseing nothing. Next idea
Old Oct 16, 2008 | 10:46 AM
rbaker6336's Avatar
rbaker6336
thereis another speed sensor on transmission that may affect it
Old Oct 16, 2008 | 01:43 PM
tloo13's Avatar
tloo13
i just had the same problem youre talking about. i changed the VSS in the rear Diff. and both speed sensors on the transmission and still had the problem.
All i did to fix it was clean the battery terminals, make sure they were all snug, and tightened the ground wire coming off of the wiring harness. check all that stuff and get back.
https://www.ford-trucks.com/forums/7...brand-new.html
not sure if that link will work but its a shot
Old Oct 16, 2008 | 02:20 PM
tinker934's Avatar
tinker934
not sure if that link will work but its a shot[/quote]
i did a little read on that post thanks when i get home later ill start looking
Old Oct 16, 2008 | 04:38 PM
tloo13's Avatar
tloo13
yeah definitely check out those little things first before you start throwing money away on sensors like i did. i spent like $150.00 before a friend told me to check the ground wires going to the body under the hood. wish i talked to him before.
let me know how you make out.
Tom
Old Oct 16, 2008 | 08:13 PM
c125bob's Avatar
c125bob
I can't offer any advice that you don't have already but know how you feel. The spedo & tranny lite are bad enough but I JUST HATE THE ABS LITE !
I fought with mine for days & days before I found a sensor wire rubbed in two near the left from wheel & tire. I still find myself checking it. Good look and I'm sure you'll get it fixed. Good help here on FTE. Stay with it !
Bob (not Fred)
