Suggestions on a cam
Old Oct 14, 2008 | 06:39 AM
wdstang's Avatar
wdstang
I have a 93 f150 5.0 aod, i pulledthe motor down and it has a roller cam in it, whats the best emission legal cam i can use?
Old Oct 14, 2008 | 08:33 AM
jerg_064's Avatar
jerg_064
I take it your still stock SD, so keep the LSA@114* or above(computer compatible). This is to keep good manifold vacuum for the MAP sensor so the computer runs the engine properly.
And in order to get as much low-end torque as possible out of it for the truck application keep your duration @.050" below 220.
If you go over .500" lift you'll need to replace the vavle springs, and you don't want to go much over .500" anyways because of clearance problems with your pistons. but you can go over a bit, i'd suggest staying under .550" lift. too much airflow and it won't have any performance increase anyways.
If i missed something i'm sure some one else will correct me.
Cam selection really depends on your application,(off-road, daily driver...etc). Also a good breathing exhaust will help net the biggest increase with the cam swap. Long tube headers are great, don't mess with shorties, the gain over stock isn't worth the money.
Do a search on summit, if you stay within the give parameters you should be safe.
I'm told that comp cam 31-255-5 is a well liked overall cam, and 35-308-8 is nice with some bolt on's(exhaust, heads, intake).
Old Oct 14, 2008 | 08:53 AM
Conanski's Avatar
Conanski
The Comp 35-349-8 seems to work pretty good in the 5.0 I just put together...
